It is currently Tue Nov 17, 2026 6:34 am
 Post subject: Play with Blender Tool Lattice
PostPosted: Mon May 23, 2016 8:20 am  (#1)
Play with Blender Tool: Lattice
I use font Bauhause 93
Add Lattice.
Conect Font with Lattice
Select vertices.
and drag and pull the Lattice.
Next step to animate the Lattice.
Late 2017 iMac Retina 4K 21,5 inch Mac OS High Sierra version 10.13.4
3,6 GHz Intel Core i7
16 GB Ram 2400 MHz DDR4
Graphic card Radeon Pro 560 4096 MB
Affinity Photo and Affinity Designers.
 Post subject: Re: Play with Blender Tool Lattice
PostPosted: Mon May 23, 2016 2:55 pm  (#2)
:coolthup
PostPosted: Thu May 26, 2016 8:33 am  (#3)
Hi There,
I don't use Blender and I don't know in depth the Blender Software which is infact a very vast and much complicated than Gimp. My knowldege about Blender spans over a hundred pages of a book about Blender and few video tutorials about it.
After seeing the above post I downloaded the program. I didn't have it as I did not need it. It took me three to four frustration-ful days to make not only above kind of text but also something useful for me.
I post a crude image of a water pitcher which I created in blender. I would definitely improve it e.g., the rim which should have two surfaces and a handle as well.
Ha Ha Ha
Bye
PostPosted: Thu May 26, 2016 10:10 am  (#4)
First time. Very good.
Yoy have already all stuff you need inside Shift+A
If you want a teapot you have on under extras.
Your pot. Start with a circle and extrude with E scale.
Add handels with E extrude
Pull out your handels.
Add color/materials Plastic/Ceramic
PostPosted: Thu May 26, 2016 10:54 am  (#5)
Thanks for this information.
I created it from Mesh (Cylinder). Then I used 'Loop Cut and Slide' option. Rest is Scaling and Extrusion.
Infact handle can be made from a Bezier Curve.
An excellent tutorial about Coffee Cup by 'Little Web Hut' has all the details. I followed it sometime ago.
Thanks.
PostPosted: Fri May 27, 2016 5:17 am  (#6)
Hi There,
In the arabian desserts Dates are staple food and fruit. Water is more precious than gold. Wherever these things are found, humans are also found.
My attempt of a palm (dates) tree and pitcher of water in Blender.
:hoh
