Going to the support page there are posts concerning the same problem (Contact Sheet missing), with answers like "Will be in the next release".
Hence, how can you show it now?
The contact sheet from the old XnView is a miss. For the new version use the File -> Print menu
There is a drop down for format, then just a matter of wading through all the other options.
As before, either print to paper or
print-to-pdf. AFAIK, no option to export to a graphics format.
No PDF printer installed? For linux there is CUPS-PDF, several for Windows, I think Win10 comes with a MS one.
