It is currently Tue Nov 17, 2026 5:24 am
 Post subject: Filter Forge at GAOTD is free today only.
PostPosted: Mon Mar 27, 2017 8:27 am  (#1)
https://www.giveawayoftheday.com/filter-forge-5-0-pro/
It only applies to version 5 with no free updates, but still, I'm very tempted. Only reason I don't bite is I'm freaking lazy to learn it. lololol
Rod's our expert here so he will attest to how great this program is. :)
edit:
OK; admit that I installed it. lol
 Post subject: Re: Filter Forge at GAOTD is free today only.
PostPosted: Mon Mar 27, 2017 11:19 am  (#2)
Question for Rod. I know he's gotten FF to work in GIMP. I get the following error. Any ideas? In the meantime, I might just add it to shellout. :)
PostPosted: Mon Mar 27, 2017 2:37 pm  (#3)
Thanks Lyle :hi5
PostPosted: Mon Mar 27, 2017 2:59 pm  (#4)
Thank You Lyle!! I am downloading it right now!!
My Sigs = My Photos
PostPosted: Mon Mar 27, 2017 3:15 pm  (#5)
i downloaded and installed it. It said it installed and all I have is a Font Forge. Something is screwy with it!
My Sigs = My Photos
PostPosted: Mon Mar 27, 2017 8:14 pm  (#6)
Nice find Lyle, thanks for posting. It might be worth mentioning the software is only 32 bit but nonetheless works very well on 64 bit systems. I added the x64 plugin to PSE, seems to work fine. Did you figure out how to add it to GIMP? Have a nice evening...Larry
PostPosted: Mon Mar 27, 2017 8:31 pm  (#7)
I finally am getting somewhere, but I am getting the same error as Lyle. I set it to shellout, but when FF launched it didn't load the shellout temporary image. I am experimenting with copying the visible image and pasting it into FF.
My Sigs = My Photos
PostPosted: Mon Mar 27, 2017 11:48 pm  (#8)
Yeah; shellout doesn't quite work (no image passed to processor). You can open the temp file if you know the path, do your processing and save the file, but this is extremely not worth it. Oh well. I PMed Rod; maybe he can answer this one. :)
PostPosted: Mon Mar 27, 2017 11:55 pm  (#9)
Well found this thread from Rod; looks like there's probably no way to get it to work with FF unfortunately. :)
viewtopic.php?f=9&t=477&sid=11fb19db5f5540fd1ae677553a372517#p4453
PostPosted: Tue Mar 28, 2017 12:10 am  (#10)
Additionally, FF works in Irfanview but get the same error as GIMP in XNView. Weird. Problem with Irfanview is Irfanview doesn't support alpha channel. :)
PostPosted: Tue Mar 28, 2017 3:02 am  (#11)
I just export my Gimp image to temp.png and open it in FF. Then save it back to temp.png after processing and open it as a layer. I keep both programs running.
My Sigs = My Photos
PostPosted: Tue Mar 28, 2017 6:06 am  (#12)
Unfortunately no there is no way to run FF through GIMP at this time. I was able to talk the guys at FF to allow Affinity Photo to run it now though.
I run Filter Forge 6 Pro through Photoshop Elements and Affinity Photo 1.5. Less stressful. :lol
Hey Lyle does this version you download from Giveaway Of The Day allow editing AND creation of filters too? Thats a big plus if it does. =)
PostPosted: Tue Mar 28, 2017 6:52 am  (#13)
It's professional version, Rod, but only x86 (not 64-bit). I had the opportunity, though, to purchase the version 6 pro for $79 (but I don't think I will ever need such power since I'm too lazy to make my own filters; lol). Thanks for the following up by the way, Rod. :)
PostPosted: Tue Mar 28, 2017 9:16 am  (#14)
I took an existing filter, modified it in the filter editor and saved it for later use. I'm not sure what I'm doing but I think I could make a filter from scratch.
My Sigs = My Photos
PostPosted: Wed Mar 29, 2017 6:32 am  (#15)
Yeah it isn't to hard. My advice is to join the Filter Forge forums and check out some of the posts there. One fella there released a PDF on creating shapes within your filters. I think you will find that interesting indeed. Also you download filters free there. https://filterforge.com/filters/recent-page1.html
@ Lyle - YEAH! i know FF is really cheap now. :lol Kinda pisses me off as i have updated at a cost of 480 dollars thus far. =) From version 1 - 6 now. You can update for a lifetime license for 289 dollars i think. That is for Pro releases. Also be careful which filters you download from the Filter Forge site as ONLY filters built with 1-5 will work on 5 pro. NONE of the version 6 filters will work. Currently there are 8k + available. FREE.
You can also buy a full set of ALL available filters for version 5 and below (about 26 dollars i believe). This will come zipped with instructions on install. But then you really don't see what you are getting.
So you really don't need to KNOW how to build filters in it. There are plenty available. =) BUT it's fun to create them. Thats how Rodilius started out!
PostPosted: Wed Mar 29, 2017 6:44 am  (#16)
Thanks Rod!! This will help immensely!
My Sigs = My Photos
PostPosted: Wed Mar 29, 2017 7:02 am  (#17)
No problem! If you need any more help just holler at me Private Message or E-Mail. =)
PostPosted: Wed Mar 29, 2017 2:18 pm  (#18)
Lost it. Anyone still have the downloaded zip file?
PostPosted: Thu Mar 30, 2017 6:14 am  (#19)
Rod wrote: Unfortunately no there is no way to run FF through GIMP at this time....
Imperfect method - for test use: Gimp_to_Filter_Forge.py [in menu: Filters/Filter Forge/Filter Forge 5...]
This plugin replaces the original file (Save / copy the original file .../Filter Forge 5/Previews/StandardImageTransparent1Lifesaver.tga - if you want to use it) serving as a preview in FF with the option:
File/Built-In Preview Images/Lifesaver & Use Transparency
The file name (very long) is copied to the clipboard - so when you save in FF you can use the keyboard shortcut: Ctrl+V
Gimp_to_Filter_Forge.zip [2.48 KiB]
Downloaded 171 times
PostPosted: Thu Mar 30, 2017 7:28 am  (#20)
Tested in GIMP-2.8.20 64 bit with Windows 10 64 bit. =)
It did load the Filter Forge 6 Pro 64 bit interface.
BUT... i couldn't save the changes. Or maybe i am doing it wrong?
Does the file have to be saved as "StandardImageTransparent1Lifesaver.tga" ?
