It is currently Tue Nov 17, 2026 6:33 am
 Post subject: VALUE Color Mode in PixaFlux - Weave Pattern Example
PostPosted: Thu Jun 15, 2017 9:23 am  (#1)
Hello,
We have added a new VALUE color mode in PixaFlux. The value color mode is similar to monochromatic, but the pixel values can be any real number value, including negative values.
We also added new VALUE nodes:
Generate nodes: Waves, Ellipsoid, Cylinder.
Value nodes: Add, Multiply, Maximum, Minimum, Absolute, Condition.
The VALUE color mode will allow you to create more organic compositions by creating, modifying and mixing images as if they were elevation or height maps.
We have uploaded a new Video Tutorial:
https://youtu.be/sFGND0z_6wY
Please let us know what you think about the new VALUE color mode.
Thank you!
PixaFlux is a non-destructive node-based image editor.
PixaFlux
Non Destructive Image Editor
 Post subject: Re: VALUE Color Mode in PixaFlux - Weave Pattern Example
PostPosted: Fri Jun 16, 2017 9:23 am  (#2)
Here is a weaved ratan set of textures created in PixaFlux using the new VALUE color mode nodes:
PixaFlux
