It is currently Wed Nov 18, 2026 9:30 am
 Post subject: POV-Ray (Persistence of Vision Raytracer)
PostPosted: Tue Aug 29, 2017 4:58 am  (#1)
As I was choosing a gradient to use in a picture in GIMP recently I inadvertently right clicked on one and saw that the drop-down menu included the option to save (the gradient) "..as POV-Ray", not having an idea what this meant I saved it anyway, then DuckDuckGo'd "POV-Ray". 'Interesting', I thought, a graphics application of some kind :) ... I downloaded and installed POV-Ray v3.7 for Windows. I soon realised the program is script-based therefore I would have to learn the ins-and-outs of the syntax used (nightmare, I'm still trying to get my head around Python lol) - anyway I've spotted some tutorials on YT (https://www.youtube.com/watch?v=1ZDWcEQrqsc for instance) so I hope to get something done with that soon... (finger's crossed). Can anybody tell me though, how can I use the file I saved (the gradient) in the POV-Ray program, not sure if anyone out there is familiar with it, but for starters I can't find anything so far in the 'POV_Ray Help' about gradients, let alone which format they have to be saved in or what one has to do with the file (maybe point to it within a POV-Ray script somehow (??)).
Anyway, would appreciate any help if anyone has a clue about it, if not I'll just soldier on hope to make something like this person's first animation(!) https://www.youtube.com/watch?v=exL5B7LapUo
Cheers.
 Post subject: Re: POV-Ray (Persistence of Vision Raytracer)
PostPosted: Tue Aug 29, 2017 7:31 am  (#2)
GIMP saves the gradient as a POV-Ray colour_map: http://www.povray.org/documentation/view/3.7.0/335/ which is a pigment modifier.
Try the example in the linked page, along with one of the standard scenes.
I'll try and find some time to experiment with it this evening.
Kevin
PostPosted: Tue Aug 29, 2017 7:38 am  (#3)
Thanks for finding that! It makes a lot more sense now, great! :)
EDIT: Just rendered my first object, using a gradient from GIMP (Basic Magenta White HSVCW):
Copied bits of code from here n there, adapted it and came up with this:
This is how I did it:
   #include "colors.inc"
camera {
   location <0,0,-5>
   look_at <0,0,0>
light_source {
   <5, 4, -8>
   White
sphere {
    <0,1,2>, 2
    pigment {
      gradient x*y+0.3
color_map {
   [0.000000 color rgbt <1.000000, 0.000000, 1.000000, 0.000000>]
   [0.500000 color rgbt <1.000000, 0.500000, 1.000000, 0.000000>]
   [1.000000 color rgbt <1.000000, 1.000000, 1.000000, 0.000000>]
PostPosted: Tue Aug 29, 2017 6:40 pm  (#4)
That's pretty nice!
My Sigs = My Photos
PostPosted: Tue Aug 29, 2017 7:12 pm  (#5)
Dang, I just watched a very impressive animation video done with POV-Ray!
PostPosted: Wed Aug 30, 2017 1:39 pm  (#6)
PhotoMaster wrote:
That's pretty nice!
Thanks! Just a start...
That's amazing, well I'm not quite there yet, only been at it a few hours !
However, managed to render a little GIF (with the help of GIMP..:) )
PostPosted: Thu Aug 31, 2017 3:25 am  (#7)
Did you do the morphing in gimp or povray? If you did it in gimp, what plugin did you use?
PostPosted: Thu Aug 31, 2017 3:45 am  (#8)
I used GIMP / 'G'MIC>Layers>Morph layers' for that, using high precision but low smoothness. I only recently discovered it tbh.
PostPosted: Thu Aug 31, 2017 7:45 am  (#9)
You can animate warping in IWARP also. For example i created an ellipse and filled it with a gradient.
Then i opened IWARP warped the oval into a fish shape and saved it as a 25 layer animation. Below is the animated PNG version
For those who cannot see the APNG file here is a GIF version.
You can get the files to add animated png (APNG) export to GIMP-2.8.22 by going here.
viewtopic.php?f=9&t=212&hilit=IWARP&start=110#p31336
32 and 64 bit files are available for the Animated PNG setup. (windows only i am afraid)
PostPosted: Thu Aug 31, 2017 8:04 am  (#10)
PostPosted: Thu Aug 31, 2017 10:55 am  (#11)
cool fishes :coolthup
Can't get the APNG thing to work, I see the option 'PNG/APNG' but trying to save it and nothing happens...
All I can do is squash or expand things, not artistic enough to warp it into an actual image (!)
PostPosted: Fri Sep 01, 2017 7:16 pm  (#12)
G'mic's layers morph plugin doesn't really morph, it mostly just cross fades. I have made warping animations with gimp's Iwarp before, but won't post them because they're not politically correct...
I've used a few morphing plugins before where you set the morphing points for the before/after images. It looks more realistic.
PostPosted: Sun Sep 03, 2017 10:26 am  (#13)
Most of the time i use flash for morphing objects. IWarp is great in a pinch though. :)
You don't have to save as an animated PNG image you can use GIF. BUT try removing the file-png.exe from the program directory /lib/gimp/2.0/plug-ins folder and GIMP should recognize either APNG multi layers or PNG single layer images.
PostPosted: Mon Sep 04, 2017 11:50 am  (#14)
OK I'll try that thanks.
PostPosted: Mon Sep 04, 2017 12:06 pm  (#15)
Great got that working now, a 720 layer 640x360 animation exported as an APNG is 73MB in this case, 55 MB's more than a GIF made with the same images (optimized) - to be expected as the colour's certainly are better in the APNG... anyway now we've strayed from the original topic of this thread (POV-Ray) by some margin :lol so I'll leave it at that for now.
Cheers
PostPosted: Mon Sep 04, 2017 10:30 pm  (#16)
:coolthup video
PostPosted: Tue Sep 05, 2017 12:38 am  (#17)
Wow! These are all pretty sharp! I do have to say that the auto engine video was amazing!
My Sigs = My Photos
PostPosted: Sun Sep 10, 2017 12:05 am  (#18)
I've used povray for creating objects I've used in mapping, and to create maps as well. It is extremely powerful, but great and easy for mathematical/scripted/repetitive shapes.
I made this paddlewheel for a top down paddlewheeler map:
Palm trees (I was able to randomize a few dozen in size and leaf orientation so they wouldn't repeat when used):
Asteroids from a videogame:
I've also used POVRay to render height-fields of objects,shapes and entire maps, like this one:
-Rob A>
PostPosted: Sun Sep 10, 2017 12:31 am  (#19)
A couple more for fun - cross eye stereogram renders of a planet from a heightfield:
And the cover art for a dice game package:
-Rob A>
PostPosted: Thu Sep 14, 2017 12:07 pm  (#20)
Really good outcomes RobA, lots of potential in the program I can see... have left it gathering dust in the corner of my desktop for now but hope to get back into it again soon.
Cheers
