It is currently Fri Oct 09, 2026 10:42 am
 Post subject: Corgi Designed Using The Golden Ratio Grid
PostPosted: Tue Jan 23, 2018 6:07 am  (#1)
Former Member
After I designed the Bird I wanted to try something a little more challenging. So I decided to design a Cordi dog using the same technique. Without using the golden ratio grid, this would be a pretty simple design but using it was a lot more challenging. This design took me 5 hours to complete from start to finish.
Designed in Gravit Designer and the psd's for the cover image was designed in GIMP.
If you just want the Golden Ratio Grid design you can download that from this topic.
corgi-golden-ratio.zip [1.12 MiB]
Downloaded 157 times
 Post subject: Re: Corgi Designed Using The Golden Ratio Grid
PostPosted: Tue Jan 23, 2018 6:15 am  (#2)
:coolthup
PostPosted: Tue Jan 23, 2018 6:28 am  (#3)
Former Member
sallyanne wrote:
:coolthup
:tyspin I added the project files for anyone who wants to play with them as well
