It is currently Fri Oct 09, 2026 10:41 am
 Post subject: Enlarge photos?
PostPosted: Mon Mar 26, 2018 9:56 pm  (#1)
I know there is a resize function in gimp. In GMIC there are a couple I think. but are any of them really intended to make smaller photos larger and still be sharp?
Looking on the net I have found smilla enlarger may do this. Has any one here tried it and can you give a review please? Or have you you any other suggestions.
 Post subject: Re: Enlarge photos?
PostPosted: Mon Mar 26, 2018 10:35 pm  (#2)
Never heard of smilla enlarger.
Raster images just don't scale well,
when scaling them much larger or smaller then what they were originally.
There's something called step-scaling,
but I haven't used it and I'm not sure if it's a script or something offered by G'Mic.
Edit: I found this at the plugin registry... http://registry.gimp.org/node/26196
Here's a screenshot of the page.
I'm not sure how well this work,
so your on your own.
PostPosted: Mon Mar 26, 2018 10:56 pm  (#3)
Thanks for replying Wallace, I hadn't heard of it before. I thought maybe someone here had since it is open source from source forge and runs using qt.
PUBLISHER'S DESCRIPTION
From Mischa Lusteck: SmillaEnlarger is a small graphical tool ( based on Qt ) to resize, especially magnify bitmaps in high quality. ( The used algorithm is an invention of my own )
But there hasn't been any reviews since 2016 and I think it was a beta version then - page has this years date on it.
Found an updated version on CNET 2017
PostPosted: Mon Mar 26, 2018 11:06 pm  (#4)
I'm not sure about this application.
I did try out the Step Scaling plugin and was surprise that it seems to work pretty well.
I used 5 steps to scale my avatar.
Here's a before and after.
I also put the plugin together in a .py file,
because it was only available as text.
Step_Scaling.zip [1.35 KiB]
Downloaded 204 times
PostPosted: Tue Mar 27, 2018 12:00 am  (#5)
Thank you Wallace. It may come in handy
PostPosted: Tue Mar 27, 2018 12:02 am  (#6)
Sure thing Sallyanne.
PostPosted: Tue Mar 27, 2018 1:50 am  (#7)
Hi
I use the next G'mic Filter Xbr2X .
I Like it - it is a good effect.
Doron
PostPosted: Tue Mar 27, 2018 2:02 am  (#8)
doronf2 wrote:
Hi
Doron
This does scale nicely,
but from what I can tell.
It doesn't seem to preserve transparency.
PostPosted: Tue Mar 27, 2018 3:34 am  (#9)
For Windows users there is a free version of Reshade that can rescale images. MareroQ even wrote a plugin to make it easy to use from within gimp.
View it here:
viewtopic.php?f=9&t=14308&p=196572&hilit=reshade#p196572
PostPosted: Tue Mar 27, 2018 4:11 pm  (#10)
It's very rare that I need to upscale an image, but when I do, I use the nnedi3 upscaler. It's the best I've seen yet, but you'll need to learn Avisynth to use it.
Here's a 4x upscale example. Unfortunately it's flattened also, but you can remove the black easy enough..
PostPosted: Tue Mar 27, 2018 4:40 pm  (#11)
For windows I can recommend:
Waifu2x-caffe:
https://github.com/lltcggie/waifu2x-caffe/releases
It works very good with images like Wallaces avatar.
And Fitswork:
https://www.fitswork.de/software/softw_en.php
tutorial:
http://www.astrofriend.eu/astronomy/tut ... swork.html
try: Fitswork>Processing>Image Geometry>.........x2 hi-f sinc
Fitswork>Bearbeiten>Bildgeometrie>Bildgröße x2 hi-f sinc (german)
But you can try the other alternatives in that menu. (also with little neural networks).
@racer-x,
Your sugestion also works with a neural network solution I think?
Do you have a nice link to good tutorials for Avisynth?
PostPosted: Wed Mar 28, 2018 3:56 am  (#12)
Avisynth is a script based video editor. It's commandline. It's a Windows program, but it works under Wine too. I rarely use it anymore, so can't help with tutorials. I'm sure you can find some out there.
You'll need the nnedi3 filter. It can only upscale in multiples of 2. Example: 2x, 4x, 8x, 16x. Here is the command I used for 4x upscale:
ImageSource("D:\path\to\image.png")
nnedi3_rpow2(4)
PostPosted: Wed Mar 28, 2018 5:27 am  (#13)
SmillaEnlarger, a bit of a monster in Windows but a small download in linux ;) . Looks like this:
I tried Smilla years ago and not all that impressed. Seems to generate artefacts and makes big file sizes.
A recommendation - ImageMagick
A long discussion and various algorithms here: https://www.imagemagick.org/Usage/filte ... upsampling
IMHO this one is as good as anything for enlarging and a little sharper.
magick small.png -colorspace RGB +sigmoidal-contrast 7.5 -define filter:window=Jinc -define filter:lobes=3 -resize 400% -sigmoidal-contrast 7.5 -colorspace sRGB bigger.png
but..whatever method used is still just guessing which pixels to add.
PostPosted: Wed Mar 28, 2018 7:48 am  (#14)
Thank you all.
I really wanted to find out if it could be done with photos. As far as I was aware - once a photo is shrunk you cannot enlarge it again. Tried one of them on a photo today and looks to me like if the information isn't there, enlarging doesn't make any difference.
PostPosted: Wed Mar 28, 2018 9:27 am  (#15)
@racer-x,
Thank you for information.
@sallyanne,
That is true. If an image is scaled-down, then the image lost pixels, therefore the image lost information.
Some neural network systems, like waifu2x, have good results, because the neural networks are trained on thousands of image pairs ( down-scaled and originals), so the neural network system based image scalers can better "guess" the information that is lost. But it isn't magic, the neural networks never recover the original information that is lost.
