It is currently Tue Nov 17, 2026 3:38 am
 Post subject: GIMP Inkscape
PostPosted: Mon Feb 18, 2019 12:30 am  (#1)
As I was randomly searching the google play store on my phone, I came across an app called GIMP Inkscape. Sounds interesting but I don't think I'd use it. Has anyone else used it?
 Post subject: Re: GIMP Inkscape
PostPosted: Mon Feb 18, 2019 2:42 am  (#2)
It's a poor attempt,
at combining 2 applications into one installer for Android phones.
This does not install one app.
It is a single installer,
which installs Gimp and Inkscape.
It's my opinion,
that both Gimp and Inkscape.
Are not very practical applications to have on a phone.
I would not recommend downloading and installing this app.
PostPosted: Mon Feb 18, 2019 4:59 am  (#3)
It's my opinion,
Especially for a phone app. I was just curious since I was looking through my phone and found apps like that one and photoshop.
PostPosted: Mon Feb 18, 2019 5:09 am  (#4)
It is horrible. It is a Linux (ubuntu) Virtual Machine with Gimp 2.8/Inkscape embedded, running in the android machine. Takes up a lot of space. I had it in an Asus 'transformer'. The Asus died before I figured out how to uninstall it ;)
Needs at least a 10" tablet. There are some less-than-serious graphic apps for android, unfortunately the good ones are not free.
cron
