It is currently Tue Nov 17, 2026 5:57 am
 Post subject: Chrome Chain in Blender.
PostPosted: Sun Jun 23, 2019 4:08 pm  (#1)
I made a chain link shape path in Gimp and exported as .svg. I then imported that svg into blender to make this chrome chain. It looks pretty darn good for a part time (rarely) Blender user.
 Post subject: Re: Chrome Chain in Blender.
PostPosted: Sun Jun 23, 2019 5:11 pm  (#2)
That's awesome! How did you extrude it? Did you use the bevel modifier?
PostPosted: Sun Jun 23, 2019 5:27 pm  (#3)
"Looks pretty darn good" ... Actually, it looks great. To me, it's hard to believe that chain isn't a photograph and isn't "real."
PostPosted: Sun Jun 23, 2019 5:39 pm  (#4)
Thanks for the complements.
I added a Bezier Circle, then pointed to it in the Bevel Object tab.
PostPosted: Sun Jun 23, 2019 5:45 pm  (#5)
Excellent chrome chain. Blender is worth learning.
PostPosted: Sun Jun 23, 2019 9:20 pm  (#6)
Racer-x - like your neat chain, so thought I would give Gimp a quick try at a steel chain. Does not have the same shine characteristics as your Blender version; probably needs more time/attention :)
PostPosted: Mon Jun 24, 2019 1:29 pm  (#7)
Pretty good though OMG.
PostPosted: Thu Jun 27, 2019 8:32 pm  (#8)
I finally got around to animating it. Blender is very hard and I rarely use it, so I forget how to set up controls for it. Lot's of trial and error.
PostPosted: Fri Jun 28, 2019 6:07 am  (#9)
Nice.
PostPosted: Fri Jun 28, 2019 6:33 am  (#10)
Very impressive - can almost hear the creaking, scraping noise it would make.
PostPosted: Fri Jun 28, 2019 9:44 am  (#11)
Indeed it does, racer-x, well done. I still have problems with good lighting.
Blender is a good program but like you, I don't use it enough to get myself into it.
The last remark applies only to me :)
And I'm surprised about the good quality in the GIF outcome :kpix
PostPosted: Fri Jun 28, 2019 7:24 pm  (#12)
Ella Louise wrote:
The attachment chrome_chain.png is no longer available
Yes, lighting can be challenging for sure. I'm going to let you in on a little secret that I've discovered. If I set the "World" to "Environmental Texture", I can use one of my many Gimp E-Maps. This let's me use some of my many Chrome and Gold reflection maps. It makes it look much more realistic, I think.
The GIF looks good at it's size because it's only 24 frames. This one has 36 frames and includes both Chrome and Gold, because I couldn't decide which one I wanted.
P.S. Don't tell anyone our little secret. ;)
PostPosted: Sat Jun 29, 2019 12:31 am  (#13)
Racer, it's very impressive. I like it a lot. :clap
OMG, there is nothing you aren't able to do. Great! :clap
PostPosted: Sat Jun 29, 2019 5:43 am  (#14)
Thank you for the explanation racer-x. I should try that out. Unfortunately not much time for Blender or Gimp at the moment.
And you can be sure, I won't tell anyone our little secret :lol
PostPosted: Sat Jun 29, 2019 8:19 am  (#15)
noice :bigthup
PostPosted: Wed Jul 03, 2019 7:46 pm  (#16)
Fantastic chains racer-x :jumpclap
PostPosted: Sun Jul 14, 2019 4:41 am  (#17)
I made a screencast tutorial on making a chrome chain in blender. Mostly so I don't forget how I did it, but anyone can try it out if they are adventurous. It's relatively simple as blender animations goes. I'm also attaching the chain path svg and the E-map I used to make the chrome reflection. Good luck trying to figure out my thick Boston accent. :hehe
Chain_files.zip [356.59 KiB]
Downloaded 377 times
PostPosted: Sun Jul 14, 2019 7:27 am  (#18)
It's great you have done that tutorial racer :clap
I'm interested in those metallic reflective surfaces and also mirror surfaces. It's nice to make elements that can be moved between different apps.
PostPosted: Sun Jul 14, 2019 4:04 pm  (#19)
Thanks Tas_mania. I've found many uses for my many E-maps and discovering I could use my path shapes in blender was pure coincidental. I rarely use blender, so consider myself a novice. The main reason for this tut is to help me remember how I did it. It seems I spend too much time trying to figure out how blender works when I finally get a chance to use it....
PostPosted: Sun Jul 14, 2019 6:24 pm  (#20)
Impressive work racer-x and thanks for the video.
I'm also now a subscriber to your channel.
