It is currently Tue Nov 17, 2026 5:58 am
 Post subject: David added Voronoi to the latest GMIC
PostPosted: Thu Apr 30, 2020 9:33 am  (#1)
I was asking David about how hard it would be to add voronoi to GMIC and he said it was simple, and it's now available in GMIC.
Have fun, Lyle and GIMPeroos!
 Post subject: Re: David added Voronoi to the latest GMIC
PostPosted: Thu Apr 30, 2020 10:46 am  (#2)
Yeeees excellent! :bigthup
Pexels Beauty Model.
Pexels Woman's Face.
PostPosted: Thu Apr 30, 2020 12:39 pm  (#3)
mahvin :wvy Nidhogg :wvy
With gmic 2.9.0, I updated the filters and I did not find the "voronoi". If it is with gmic 2.9.1prerelease I did not find it for download for Windows here:
https://gmic.eu/files/windows/
PostPosted: Thu Apr 30, 2020 1:03 pm  (#4)
Yes, it's under patterns in 2.9.1_pre#200425, you will have to wait a minute.
PostPosted: Thu Apr 30, 2020 1:21 pm  (#5)
Irony is, I don't have the GMIC 2.9.0 and until I learn to package GMIC for Macs, I'll be without on this machine. It's just nice to know that the filter was so simple, that Dave implemented it into GMIC. So, I'll be grabbing the laptops and upgrading Linux, instead!
PostPosted: Thu Apr 30, 2020 1:28 pm  (#6)
Thank you Nidhogg because I did the search "voronoi":
and not "voronoï" ;)
PostPosted: Thu Apr 30, 2020 4:12 pm  (#7)
Was using Polygonize>Delauny before, Mahvin. Will check out the Voronoi preset soon.
minutes later.....
OK; definitely much cleaner results than with Polygonize>Delauny. Thanks for the heads-up, Mahvin. :)
PostPosted: Thu Apr 30, 2020 4:50 pm  (#8)
Lylejk, you got a blow on the head .... :) now I understand better your crazy creations ! ;)
PostPosted: Thu Apr 30, 2020 5:49 pm  (#9)
I compiled the Voronoi Path plugin for Mac and it's working well, as well. Now back to the laptop and compiling GMIC for Linux
PostPosted: Thu Apr 30, 2020 6:27 pm  (#10)
I don't compile G'mic for lynux, I just use one from here: https://github.com/aferrero2707/gimp-pl ... continuous
It works great and is always updated. Run the GMIC appimage then locate the created gmic_gimp_qt file and copy it to your appropriate Plugins folder. It works with Gimp appimages and otto's PPA.
PostPosted: Thu Apr 30, 2020 6:49 pm  (#11)
What release do you have of GMIC? I'm only getting release 2.7.5 and 2.9.0+ is required to use Voronoi in Patterns.
PostPosted: Thu Apr 30, 2020 6:58 pm  (#12)
Definitely makes a more stained glass like pattern now. Have some ideas for future stain glass renders, but they will require more work then just running the preset on a complete image. Again, thanks for the head's up, Mahvin. :)
ref: http://www.fontplay.com/freephotos/fift ... 306-09.jpg
https://www.flickr.com/photos/163034485 ... 33/sizes/o
PostPosted: Thu Apr 30, 2020 7:08 pm  (#13)
I have G'mic v2.9.0 and it has Voronoi after a filter update.
PostPosted: Thu Apr 30, 2020 11:02 pm  (#14)
PostPosted: Sat May 02, 2020 1:33 pm  (#15)
Ever the Irishman, simple never works for me. Just my luck. AppImage just didn't work. I even globally added exec's along with libraries, and nada. I prayed to Odin, no response. You see, compiling always works for me, even if the distro says "We can't update this dependency just because...(irrelevant reason)" I simply refuse to accept that as an answer, and press on. Anyway, GDebi did the job and my Linux world is righted. This went so far that 4 developers got into a verbal spat over "forcing" dependencies. Now Otto's PPA, there is a good man, who does what I like doing: helping make others' world go round.
PostPosted: Sat May 02, 2020 5:01 pm  (#16)
What type of gimp install do you have? Is it Otto's PPA, Flatpak, Snap, appImage or straight compile? Also, what Linux distro are you using?
PostPosted: Sat May 02, 2020 5:33 pm  (#17)
I had Snap but removed it because it wouldn't allow access to plugins folder. I used Otto's PPA for GMIC, finished with GDebi. On this cheap Dell laptop, I'm running recently upgraded Ubuntu 20.04. I tried using his PPA for GIMP and ran into errors with libgegl and libgimp, so went looking for answers on irc and given a new PPA and instructions on how to force failed dependencies to install anyway. 20.04 isn't flexible at the moment, I should have waited. I actually don't compile, the computer does. I guess you could say that doing things the hard way keeps me aware of troubleshooting and resolutions.
PostPosted: Sat May 02, 2020 6:14 pm  (#18)
This one doesn't work for you? It comes with G'mic already installed. Be sure to make it executable before you run it. Direct Link to Gimp 2.10.19 with plugins AppImage: https://github.com/aferrero2707/gimp-ap ... 4.AppImage
PostPosted: Sat May 02, 2020 6:27 pm  (#19)
I did that. No cigar. Made it executable, ran it, then blank. Everything is working now, so I bookmarked the link you provided to the dual program for later attempts.
PostPosted: Sun May 03, 2020 10:07 pm  (#20)
The AppImage file finally worked. I'm starting to think that the delay with internet speed and this laptop being 7 years old, its probably due to my impatience that it seemed it wasn't working. I walked away this time, and when I returned the AppImage file was there for me to click on it. THANK YOU, racer-x! :bigthup
