It is currently Tue Nov 17, 2026 7:31 am
 Post subject: scribus
PostPosted: Tue Jun 14, 2011 10:25 am  (#1)
ok so i downloaded scribus and i have know idea what i'm doing, i need a manual and perhaps some tuts to get started, can someone help? thanks
 Post subject: Re: scribus
PostPosted: Tue Jun 14, 2011 10:40 am  (#2)
I don't know anything about Scribus but I found this Scribus Forum. You may find what you need in that. Click Here
PostPosted: Tue Jun 14, 2011 10:52 am  (#3)
First open Scribus and go to help (top menu) and click manual or online tutorials if you are online at the time.
Example
Try those first. :)
PostPosted: Tue Jun 14, 2011 10:55 am  (#4)
Scribus takes some getting used to but once you get comfortable with it it's great.
PostPosted: Tue Jun 14, 2011 6:05 pm  (#5)
Scribus is awesome. I create most of my documents in it because it creates beautiful pdf files. It does take a little getting use to, the way you add and edit some elements, but I always tell my friends and students, "Just play with all the buttons and see what they do." You'll like it, I promise. I actually do our weekly church bulletins in the program.
May 8 New format - bulletin2.pdf [5.09 MiB]
Downloaded 263 times
PostPosted: Tue Jun 14, 2011 7:34 pm  (#6)
nixnine wrote:
......but I always tell my friends and students, "Just play with all the buttons and see what they do."
I agree. I've preached that for years. The best way to learn any software is to try every button and menu and try everything the application will do. The worst mistake I think people make is: 1 - to be afraid of the software, and 2 - to want to dive right in and start making serious projects when they don't know the software yet. I always advise people to just fool around with whatever the application is and have fun before they try to use it for real life work.
PostPosted: Tue Jun 14, 2011 7:40 pm  (#7)
These are good Dai has a very good knowledge of Scribus and has a nice soft voice that's easy to listen to.
