It is currently Tue Nov 17, 2026 12:42 am
 Post subject: Dove
PostPosted: Sun Sep 15, 2024 9:36 am  (#1)
Just doodling around playing in Krita with brushes I don't usually use and layer modes. It looks like a Prog Rock album cover! :hehe
 Post subject: Re: Dove
PostPosted: Mon Sep 16, 2024 8:59 pm  (#2)
:bigthup :paint
PostPosted: Tue Sep 17, 2024 4:18 am  (#3)
sallyanne wrote:
:bigthup :paint
Thank you Sallyanne. I tried to replicate it in Gimp but it lacks the special brush for the swirls and it lacks colour dodge layer mode. I tried working on a dodge layer mode but it's not the same. Maybe one day they will implement it.
PostPosted: Fri Sep 20, 2024 12:24 am  (#4)
Have you tried making the brush in gimp Erisian? You can make them with paths as well you know and save as a brush.
Question? What's the difference between dodge and colour dodge layer mode?
PostPosted: Fri Sep 20, 2024 2:40 am  (#5)
Erisian my old mate- thank you for the challenge of replicating the 'Dove' in Gimp. Quickly made 6 or so quick brushes to help out, then just went with the flow :hehe
PostPosted: Fri Sep 20, 2024 3:05 am  (#6)
:clap Really an artistic creation, Thanks Erisian and OMG. :paint
PostPosted: Fri Sep 20, 2024 5:29 am  (#7)
Issabella - thank you.
OMG - nicely done. Did you keep the swirls from the original?
Sallyanne - the brush has a particular effect that I like. When you draw a line and in the same stroke change direction to create a corner, the corner is automatically filled in. It also happens when, in the same stroke, you cross your line - it creates fill-ins in the corners of the cross. There was a way to do it in Gimp using a small stack of legacy layer modes including legacy burn mode and a fuzzy brush but I cannot remember it and cannot replicate it.
Colour dodge mode is mathematically different from dodge and creates a different effect, saturating colours so that they glow like coloured lights. Dodge does this to some degree too but it is not the same. Krita has three dodge modes: Easy dodge, Linear dodge and color dodge and they all give different effects.
PostPosted: Fri Sep 20, 2024 5:49 am  (#8)
Erisian - re "Did you keep the swirls from the original" - everything was done from the ground up in Gimp, using paths to create brushes to replicate those 'swirls'. Once they are painted on the canvas, they could obviously be embellished if required.
PostPosted: Fri Sep 20, 2024 6:07 am  (#9)
Oh yes. I just had a closer look and I can see the differences between yours and mine. You did that really well!
