It is currently Tue Nov 17, 2026 7:32 am
 Post subject: My friend Pablo at Web Builder
PostPosted: Sat Jul 09, 2011 11:54 pm  (#1)
has recently released a test beta version of his Quick and Easy Web Builder Suite.
Thought you might have fun playing with it. :)
Comes in 3 flavors...
Windows
Mac
Linux
Downloads and screen shots for each version can be found here
http://www.quickandeasywebbuilder.com/
This is actually just a small version of Web Builder 7.Created to allow Linux, and Mac users to have the program.
I believe if this smaller version tests out ok then they will be building a full fledged version of Web Builder 7 for Mac and Linux.This program allows you to build websites very fast that are attractive looking.
I downloaded the windows version (no need to install any of the beta versions), and find it to be a nice little version of Web Builder.Make sure to download the PDF INFO file also.
http://www.quickandeasywebbuilder.com/qnewb_info.zip :)
Enjoy!
 Post subject: Re: My friend Pablo at Web Builder
PostPosted: Sun Jul 10, 2011 12:03 am  (#2)
Just a couple quick things
Tools in the right hand menu can be manipulated by drag and drop and then in the left hand properties menu are all your selections to adjust the tool.Such as the tool shapes - adjust it by using the properties dialog in the left menu.
Any tool can be dragged and dropped onto the canvas and then adjusted via the properties dialog.
You will get a nag screen every time you launch warning you its a test version. :) (just a small one)
Be sure and read the INFO PDF for more help.
PostPosted: Sun Jul 10, 2011 12:19 am  (#3)
I'll see if I can use the mac version. I'm a bit thick when it comes to this type of thing!
PostPosted: Sun Jul 10, 2011 7:50 am  (#4)
I'm wondering if it's any better or easier than the iWeb for mac? I haven't had the chance to try that yet but it's supposed to be easy, too.
PostPosted: Sun Jul 10, 2011 8:32 am  (#5)
iweb is so easy blind freddy could use it...I dont have much luck with other web builders myself but I have put together a couple of other things using iweb.
PostPosted: Sun Jul 10, 2011 9:46 pm  (#6)
Argh, if only I had, say, another day in each week, maybe I could find time to play and learn all this stuff. I haven't touched iweb nor imovie yet, and I've had my macbook since Christmas.
