It is currently Tue Nov 17, 2026 7:32 am
 Post subject: Created my first Filter for Filter Forge 3 beta.
PostPosted: Sun Aug 21, 2011 1:06 am  (#1)
I call it cast Iron Pan. :hehe
If you want the filter just PM me. :)
 Post subject: Re: Created my first Filter for Filter Forge 3 beta.
PostPosted: Sun Aug 21, 2011 4:17 am  (#2)
very nice Rod. I love that tree.
PostPosted: Sun Aug 21, 2011 6:35 am  (#3)
Will it work on my mac?? I'd love to try it...I'm suitably impressed with the effect!
PostPosted: Sun Aug 21, 2011 1:35 pm  (#4)
What is filter forge 3 beta, Rod? Love the effect. Cast Iron Pan is a perfect name for it, but don't use my cast iron skillet. It's precious to me. :hehe
PostPosted: Sun Aug 21, 2011 1:53 pm  (#5)
The program is available for Mac or Windows.30 day trial fully functional other than filter building or bump map creations.You can only do that with Standard or Pro licenses.I own one for Filter Forge 2 (Pro).
There is a Basic version for 40 dollars that allows you to download any of the existing 8200 filters for it.
O - FF 3 beta is a test version of the upcoming Filter Forge 3. Filter Forge is a program you can either use standalone (with the filters) or with PS, as a 8bf plugin. :)
Filter Forge can either add textures, and/or effects to your image or you can use it to create new filters. :)
Pretty cool.
To use my filter you have to download Filter Forge 3 Basic.(trial)
Then download my filter and place it in your Application Data/Filter Forge 3/My Filters folder.
Open Filter Forge 3 and click My Folders in the library pane and there you go.There are 3 presets with it already.You can edit pixel size for the cast edges (roughness), and all lighting effects.
I was pretty sure Filter Forge 3 Basic was available.
Anyone who owned a license for FF2 Pro got a free beta version of 3 for testing.That is what i built the filter with so that is the version you need to run it.
I could rebuild the filter in Filter Forge 2 though.I know that version is available for trial download.
I thought i saw Filter Forge 3 in the downloads section.Guess it's still not available.
Sorry folks.
PostPosted: Sun Aug 21, 2011 10:08 pm  (#6)
for those that prefer to use Linux is there a filter that works similarly?
or can be added to G'Mic?
PostPosted: Mon Aug 22, 2011 2:05 am  (#7)
Sorry cecillia but Filter Forge isn't available in Linux yet. :\
Using gradient fills, and noise could basicly duplicate this effect.Maybe add dd's bevel script.
PostPosted: Mon Aug 22, 2011 10:55 am  (#8)
ok, I still have a lot to learn with the filters i DO have, so, it's not a big deal
