It is currently Tue Nov 17, 2026 7:32 am
 Post subject: me...again
PostPosted: Mon Sep 05, 2011 9:25 am  (#1)
Hello to All of You wonders of photo editing.
Can someone please explain how that works?
http://photofunia.com/
is the software used available as a free software or is possible to make
using Gimp?
Thank You again for helping resolving,yet another mystery for me :)
 Post subject: Re: me...again
PostPosted: Tue Sep 06, 2011 8:22 am  (#2)
The program is a server side application.
You can install itunes and get it that way.
http://itunes.apple.com/us/app/photofun ... 40709?mt=8
Cool site though. :)
PostPosted: Tue Sep 06, 2011 8:38 am  (#3)
Thank You for your reply :)
But the app will only let me use the graphics in the app,no?
What I was trying to figure out is ,can i use the app by using my own graphics and let the app add the faces i want ?
PostPosted: Tue Sep 06, 2011 10:32 am  (#4)
If you want more versatility try Robs shellout python script.It gives Gimp many more programs, and filters to work with.
You can run Xnview through Rob A's shellout script if you have python for Gimp installed.
This script calls another graphics program, and exports a selected layer or the visible image to that other program. You can then run many types of filters (not just 8bf's) on it in whichever program you export the layer too, then export it back to Gimp with the effects on the layer or visible image. :)
I actually call Paint.Net and use Liquify (almost exactly like PhotoShops liquify filter), on my images.
PostPosted: Tue Sep 06, 2011 10:37 am  (#5)
Cool :)
Thank You so much !
PostPosted: Tue Sep 06, 2011 10:40 am  (#6)
pirate541 wrote:
Cool :)
Thank You so much !
You are welcome, and if you need help editing your shellout script to call certain programs just holler at me. :)
The script comes all set to call XnView if you have it installed.Many people use XnView to run Photo Shop filters.
PostPosted: Tue Sep 06, 2011 10:51 am  (#7)
Hollering :)
I d/led Python in plugins,but it is not showing in the filters tab
I read some of the comments,and it says it doesn't always work?
i have winXP,do i need an older version of python?
PostPosted: Tue Sep 06, 2011 11:02 am  (#8)
That photofunia app is only for iphone, ipad, and ipod...not for the computer.
PostPosted: Tue Sep 06, 2011 11:18 am  (#9)
Yes i noticed.
I was trying to find out if there were similar programs we can use on our own
with gimp
:crash
PostPosted: Tue Sep 06, 2011 11:56 am  (#10)
pirate541 wrote:
Hollering :)
Try this tutorial by Rod viewtopic.php?f=10&t=2277
PostPosted: Tue Sep 06, 2011 12:01 pm  (#11)
Thank You Molly :yr
PostPosted: Tue Sep 06, 2011 4:26 pm  (#12)
I did all of the attached:
Now you will see an area called system variables.In the window you should be able to scroll to an entry named Path.Click the path line in the window - now click edit - another dialog will open in the VALUE area you will see a long line of variables add this at the very end INCLUDING the semicolon at the beginning.
;C:\Python26\bin;C:\Python26\lib;C:\Python26\tcl;C:\Python26\Libs
but fog filter stays grey.
Python shows a console and program directory shows correct
so now what? :gaah
(Select ok, then ok, then ok again
Now restart your machine.
The variable value should be recognizable by Windows and Gimp now.Restart Gimp and look for the menu entries, and test to make sure they work.I usually run the Filters/Render/Clouds/Fog filter.
If this does not fix the problem check to see if the files
YourProgramDirectory\GIMP-2.0\lib\gimp\2.0\interpreters\pygimp,interp AND
YourProgramDirectory\GIMP-2.0\lib\gimp\2.0\environ\pygimp.env are in those two directories!
DO NOT MOVE OR EDIT THESE TWO FILES! - unless you know what you are doing.)
PostPosted: Tue Sep 06, 2011 4:58 pm  (#13)
Pirate541, were you able to get Python installed? I see a post under the one where you said thank you and I can't tell if you have it working or not. If you can't get clouds > fog filter to work, then it isn't working.
PostPosted: Tue Sep 06, 2011 5:06 pm  (#14)
the thank you was for giving me the link to get instructions.
then i installed,following the topic step by step.
it shows in scriptfu the console for python and i added the path
and it shows GIMP-2.0\lib\gimp\2.0\interpreters\pygimp,interp and
but no fog
PostPosted: Tue Sep 06, 2011 5:31 pm  (#15)
Molly
I reinstalled again,it is working now
Thank You for helping me :yes
PostPosted: Tue Sep 06, 2011 5:46 pm  (#16)
woo hoo. good. hope you enjoy it. I like the filter where you make the picture frames. filters > map > wrap bitmap (bucket) at the bottom. Here is a tute by Mahvin for it and there is another tute in the tutorials for the same thing but a different setup. http://www.mahvin.com/?p=2336
