It is currently Wed Nov 18, 2026 10:41 am
 Post subject: Chasys Draw IES (new version)
PostPosted: Wed Oct 12, 2011 10:36 am  (#1)
From Kenya a new version of Chasys Draw IES is out.http://www.chachaslab.com/chasys_draw_ies.php
It may seems to good to be true but IS good (not comparing to Gimp here are too different as concept) and is one man only
work!!
Last changes
Full-screen mode for Artist
AQuE 2.0 (Anti-Quantization Engine)
Improved Tablet support (Brush Engine 2.5)
Arrow-head option for Line and Curve tools
New image presets
Thumbnails in recent-list
New UI for Levels adjustment
Improved support for AVI video files
Preview speed-up for animations in Artist
Comic-strip view for animations
Change of terminology: Texturizer is now "Roughen Tool"
FastExternals 2.41 with pi_BasicColor
Improved Photoshop 8BF for IES functionality
Some workspace optimizations
Jitter-corrected Video Screen Capture
 Post subject: Re: Chasys Draw IES (new version)
PostPosted: Wed Oct 12, 2011 10:40 am  (#2)
Yes i get updates for this program quite often.
You can actually use this program to open and view Gimp gradients, and brushes.
Pretty handy.
It is also an excellent Shellout addition to Gimp. :)
PostPosted: Wed Oct 12, 2011 2:29 pm  (#3)
Is that some other software which you use with gimp? I know Rod had said it views the gradients and the brushes
PostPosted: Wed Oct 12, 2011 2:36 pm  (#4)
It is actually a whole other graphic creation suite for Windows.
It is freeware but not free source.
It can read gimps gradient and brush files.As well as use Adobe filters effects (8bf's).
Sometimes if i want to see what a gradient file i downloaded for Gimp looks like i will open it in Chasey Draws viewer.
