It is currently Tue Nov 17, 2026 1:05 am
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Pixelitor rocks !
PostPosted: Tue Dec 06, 2011 12:39 pm  (#1)
I rediscover this little jewel , free, more then free oOpen Sourve, easy to install, compact
(no registry entry may work as portable and/or be used from Gimp and ShellOut script)
No problems for Mac Windows or Linux version:
there is a Windows version and the java version is for all OS
It is a complete graphic editor , i was mostly attracted from some quite unique filters and effect
Worth exploring
http://pixelitor.sourceforge.net/
 Post subject: Re: Pixelitor rocks !
PostPosted: Tue Dec 06, 2011 12:58 pm  (#2)
Link?
PostPosted: Tue Dec 06, 2011 1:34 pm  (#3)
I haven't tried it but here is the link
PostPosted: Wed Dec 07, 2011 6:43 am  (#4)
looks like it could be fun!
PostPosted: Sat May 14, 2022 12:26 pm  (#5)
I am Pixelitor's biggest fan. It has non-destructive filters, gradients and vector layers now
PostPosted: Sat May 14, 2022 12:41 pm  (#6)
Pixelitor is the most non-destructive open source image editor. I LOVE IT!
PostPosted: Sat May 14, 2022 1:41 pm  (#7)
I installed it... and gave it a try. Very nice, well worth it. Thank you for sharing.
PostPosted: Sat May 14, 2022 2:34 pm  (#8)
Enable Experimental options if you want to use smart filters, editable gradients and vector layers
PostPosted: Sun May 15, 2022 2:25 am  (#9)
How?
PostPosted: Sun May 15, 2022 6:33 am  (#10)
Hi Diego
Didn't you look for it or it doesn't work? :mrgreen:
Edit ➤ Preferences
PostPosted: Sun May 15, 2022 7:48 am  (#11)
Thanks a lot, I'm becoming older and older...My neurons are diminishing every day...
PostPosted: Mon May 16, 2022 8:51 am  (#12)
I am using a beta bulld post Pixelitor 4.30 that allows moving and resizing smart filters. You'd have to build Pixelitor yourself if you want to do that or wait for a 4.31 4.x release.
PostPosted: Sat May 28, 2022 10:17 am  (#13)
Pixelitor's beta now has a new flat theme. It would not have been possible if a contributor did not solve a bug with the opacity meter. The only way to access this version of Pixelitor is to build from source.
PostPosted: Sun Jun 12, 2022 10:36 pm  (#14)
I can't stress enough how much I love Pixelitor. I wish more people used it here. It is one of the best gems in open source!
PostPosted: Thu Sep 14, 2023 10:39 am  (#15)
Pixelitor just got a new version release that has adjustment layers and smart objects in experimental options. I've been using them (reeditable filters) for over two years now but not many Gimp fans have gotten to test stuff like this.
https://github.com/lbalazscs/Pixelitor/releases
PostPosted: Thu Sep 14, 2023 12:35 pm  (#16)
From what I can make out at first reading, it can't do anything that Krita can't do and I already have Krita for painting. I imagine it's a lot lighter than Krita if you don't need good painting tools though. Also, Krita has G'mic which I really can't do without. Still, it looks like a great product.
PostPosted: Fri Sep 15, 2023 7:41 am  (#17)
Hi Erisian, You can't compare it to Krita, they are not playing the same game. ;)
Pixelitor is not for painting (at least not like Krita, not at all), it's more like GIMP using its filters, :bigthup
Pixelitor has a bunch of filters from Artistic, Light, Noise, Rendering, and so on and on...
A lot of those filters are, IMHO, more powerful than the ones in GIMP (more options and/with different options) which can surprise you when you push the cursors/sliders.
Something to be mentioned about Pixelitor: There is a "Randomize Settings" button on each and every single filter, which I found, is a very smart way to teach beginners with Pixelitor, click that button and something new comes to screen (alive like GEGL in GIMP, no need to close or apply the filter), look what changed with the default settings and boom in 2 or 3 test you understand all the filter's settings
For example:
Another example
first with default settings to make a wood texture (GIMP does not have this filter :hehe )
Then I clicked "Randomize Settings" and just put back the default gradient = a different wood texture ;)
GIMP has more powerful tools, more functionalities like the Path dialogs, the Channel dialog, but filter wise, Pixelitor can surprise ;)
Patrice
PostPosted: Wed Dec 06, 2023 11:53 pm  (#18)
Pixelitor can now call GMIC filters. Only a handful have GUIs though but it allows GMIC syntax input for anything.
PostPosted: Wed Dec 06, 2023 11:56 pm  (#19)
You have to compile the latest Pixelitor, check this and restart Pixelitor for it to work.
PostPosted: Thu Dec 07, 2023 7:08 am  (#20)
Woww!
Pixelitor is getting to the next level with G'MIC, it's a huge step up IMO
Thanks contrast_ for the news
Patrice
