It is currently Wed Nov 18, 2026 10:37 pm
 Post subject: Krita
PostPosted: Fri Apr 20, 2012 3:17 am  (#1)
http://krita.org/
Has anyone here tried it? I've been meaning to try it for a while now, but haven't got around to it... seems to have an impressive list of features for digital painting/drawing.
I might give it a shot in the near future, I just have to figure out how to install it...
 Post subject: Re: Krita
PostPosted: Fri Apr 20, 2012 8:47 am  (#2)
The windows version is Alpha/beta but I've downloaded it and will be giving it a test run shortly.
PostPosted: Fri Apr 20, 2012 9:04 am  (#3)
dd wrote:
http://krita.org/
You can probably get much more information from the downloadable PDF here.
http://krita.org/about-krita-2-4.pdf
The set of default brush tips, patterns and gradients has been completely revised and is now
based on Ramon Miranda's GPS pack2.
That is interesting.
PostPosted: Fri Apr 20, 2012 9:34 am  (#4)
I wanted to check out not only Krita but Karbon as well so i downloaded and installed the entire Calligra suite of programs for Windows.The installer is advertised as un stable though. I will test and let you know.
The PDF has this information -
System Requirements
 Krita is pervasively multi-threaded and can use all cores in a multi-core machine. Krita is
not particularly memory-efficient, eschewing saving on memory usage for speed. A dual
core CPU plus 4GB of memory is the recommended minimum for serious work.
 Krita is primarily a Linux/Unix application, but is experimentally available on Windows.
 Krita supports color management: a calibrated and profiled monitor is preferred for
dependable results.
 Optionally, Krita can make use of OpenGL to improve graphics performance and give oncanvas
preview of gradients. In OpenGL mode, Krita can use monitors that support 12 or
16 bit channel depths.
 Krita has a customizable GUI where all GUI elements can be undocked and moved to a
second monitor. Krita can show an image in more than one window at a time.
 In order to make the best use of Krita's brush engines, use of a Wacom tablet is
recommended. Other brands of tablet are not supported.
That means my HanWang tablet may not work with it. :)
PostPosted: Fri Apr 20, 2012 9:36 am  (#5)
The Windows version is Apha 1 and is very buggy. I couldn't create a 1024x768 document and had to reduce the size. There is no pressure sensitivity on my Wacom although Krita supports it. Layer modes are more complex than the standard. If you choose Darken for example, another window opens to allow more options. This looks like an excellent future product but will take a lot more work to complete.
PostPosted: Fri Apr 20, 2012 9:53 am  (#6)
Erisian are you using the suite build for Windows?
I did notice at the end of the installer it builds more dependency libraries.
I am still waiting for the interface to load.I picked my template (1024x1024)
Yeah this is probably going to get un installed :lol
PostPosted: Fri Apr 20, 2012 10:43 am  (#7)
Yeah, I uninstalled mine. It takes forever!
PostPosted: Fri Apr 20, 2012 1:26 pm  (#8)
Yeah I was planning on installing it on ubuntu, but I haven't yet figured if I should try compiling it from source or installing the package... from what I understand it requires it's own desktop environment or something to run on ubuntu...?
The windows version is probably really buggy so I'm not even going to bother with that...
PostPosted: Fri Apr 20, 2012 4:52 pm  (#9)
Nope. It's better integrated with KDE than with Gnome, but it should run over a Gnome or even a Unity desktop. Of course it may require a bit more dependent packages to install if you are not using KDE.
PostPosted: Fri Apr 20, 2012 9:14 pm  (#10)
Ok yeah you're right... well I got it installed now, I'm going to try it out then.
PostPosted: Fri Apr 20, 2012 9:48 pm  (#11)
On Kubuntu 11.10 Oneiric (or Ubuntu) you follow these instructions:
http://www.kubuntu.org/news/calligra-2.4.0
Then:
sudo apt-get install krita
In Kubuntu 12.04 the packages of Krita 2.4 (all Calligra) are in the official repositories.
PostPosted: Sat Apr 21, 2012 5:53 am  (#12)
I've been trying it out somewhat now and all I can say is it's really impressive... the feature set is plain overwhelming, it's going to take a while just to get a hang of all the features and learn everything it can do.
So far I've just been trying the different brush engines and playing with the symmetry tool, which is something I really miss in gimp... makes me all nostalgic for when I used to play with Deluxe paint on amiga 500...
PostPosted: Sat Apr 21, 2012 9:52 am  (#13)
I tried installing it on Ubuntu 11.10 64bit the other day, using the Project Neon thing. It creates a separate login, where you can run it....so it's probably preferable if you can install it manually with your normal login.
I tested it a little bit. It has a lot of features, but I found the brushes to be really slow, especially small ones (more stamps being created). It also crashed on me a few times. I really like some of the features in it, but I can't really use it for drawing, so I guess I'm sticking with Gimp and MyPaint for now. :)
PostPosted: Sat Apr 21, 2012 10:09 am  (#14)
At least on 12.04, you can just add the repository and then install it from the software center, no need to use the project neon thing or compile from source.
If you install the project neon thing, I think it uses the development version, which may obviously be less stable...
PostPosted: Sun Apr 22, 2012 11:49 am  (#15)
So, I was trying out some features of Krita today.
I drew this using sketch brush + symmetry tool...
PostPosted: Sun Apr 22, 2012 5:32 pm  (#16)
Here's another
Man, I love the symmetry tool. Went a bit over the edges though, should have resized the canvas for this one. Oh well...
PostPosted: Sun Apr 22, 2012 6:03 pm  (#17)
Some interesting work there. Now I've got Fedora I might have another look at Krita.
