It is currently Wed Nov 18, 2026 10:46 pm
 Post subject: JuliaShapes Frac
PostPosted: Sun Apr 22, 2012 2:48 pm  (#1)
Looks interesting. It's for rendering Julia fractals.
Small download.
http://downloads.zdnet.com/abstract.asp ... id=3720179
 Post subject: Re: JuliaShapes Frac
PostPosted: Sun Apr 22, 2012 6:45 pm  (#2)
Julia quaternions can be fun. Quaternions are difficult to work with but this visual approach looks quite simple. I created a Julia quat in Mandelbulb 3D. This will give you an idea how good they can look, although this one is sliced on the z plane.
PostPosted: Sun Apr 22, 2012 8:16 pm  (#3)
:clap :clap :clap that is beautiful Erisian !
PostPosted: Mon Apr 23, 2012 12:27 am  (#4)
Very nice. I'm new to Mandelbulb 3D, I'll have to have a look see.
PostPosted: Mon Apr 23, 2012 12:41 am  (#5)
Here's a quick look at what Julia Shapes will do.
PostPosted: Mon Apr 23, 2012 12:50 am  (#6)
One more just for the fun of it.
PostPosted: Mon Apr 23, 2012 4:50 am  (#7)
Thanks both. That last image probably uses similar parameters to this one.
http://www.fractalforums.com/index.php? ... ew;id=6254
Mandelbulb 3D is a bit difficult and takes time to get used to. Te software you used looks a whole lot easier although it obviously can't do as much. Probably a good introduction to quaternion fractals.
PostPosted: Mon Apr 23, 2012 5:38 am  (#8)
I'm actually surprised at the options available in the program. No manual equations. It renders quite quickly and only 377 kb.
PostPosted: Mon Apr 23, 2012 6:07 am  (#9)
I like the idea of sliders as I actually know very little about fractals. Nearly everything I do in M3D is trial and error. I'm going to have a go with Julia Shapes.
PostPosted: Tue Apr 24, 2012 2:06 am  (#10)
you can not believe the effect of a 2D Julia fractal if used as color map in M3D
I just did some experiment not sure if post also in the Art board (are not gimp artwork , the simple standard postwork i do may be done in gimp as in the most simple image viewer : i render big, apply gaussian blur of 1 to max 2px , usually no more than 1, scale down, and try automatic level
Automatic level often improve but tend to remove color cast,
Remove color cast in theory is a good thing but from a aesthetic point of view may be not, especially in case of 3Dfractals enlighten by colored lights.
but in case work well but not for the color i may recover the original color cast thank to the Magic of Gimp "Fade", to apply the change in value mode (= in simple word only to the grayscale leaving untouched previous hue and saturation )
last just scale down as needed
maybe i should write a "How get immediate results with M3D for Dummies" tutorial...
Back to 2d julia mapped in 3D fractal, i post something soon, finally i managed to save in sync also the color map used,
so finally i may include in a pack...before when giving the parameter i was feeling as cheating because i was sure that without a similar map was impossible recreate the same effect, not only for the colors but even for the shapes (shapes remain the same but different shadow and color may completltly change their percection , as example adding cavities, holes , protuberances and relieves ).
well i will upload something soon..quite excited by the last result , but are still unpolished on my USB drive --
PostPosted: Tue Apr 24, 2012 8:13 am  (#11)
I'm looking forward to it.
PostPosted: Tue Apr 24, 2012 10:04 am  (#12)
i may give a very short preview,
about how much different map may change the same fractal...
unfortunately mapping is not seamless...here you may see a lot of seams (but most could be quickly edited)
and on organic maps seams are less evidents
Ps the BG was 1 of my attempt to tweak one of your fractals...as i was not too happy of my tweak but used here as BG looks fine
But i was talking about use 2d fractal (even little as color map for M3D so here 3 different maps..
Obviously the trick is the map, here the menacing and metallic map
here the greenery ..oopss sorry i forgot to copy the greenary..ok this was a little apophysis fractal
and the most crazy (that obviously show more evident seams )
ahh the parameters..
1)
Mandelbulb3Dv17{
W.....g2...2C...w....2Q...k46yyX1g4JzAHoGLlBe2/EWqGX/0j.zz1GaSaiNLV2.h47bzL8SCvD
................................jTl36yqW8/2........Y./..................y.2..UAF
..........UE2....M.2/....6U7G...m/....E4......M/hnNwE4iD/.......Ueuj1dkpXm1.MP9.
./kuh4ED12..12EnAnAnA1R6.rAnAnAnAvwDOaNaNaNimz1............u1....y1...sD...../..
.wHnAnIDlGKo4ohNcuX9ROTMHpEpyEbUVwAtpjhD.hw3K.TOYuv2oyKXZ.0ry2.4sI3sZHhjlaOGdd.R
VvPvI9uaYFvOyOeF/MjS2zeD......2Y53............kD.2....sD..kz............OaNaNaNa
D.A..........ckpXm1...sD....z.qRo4..sFP.UW5h/.ISo4.stFP..e5h/.mSo4......B....k1.
.....MEUZz1.....gzzzVyzzzPUC.M5.a.....2...UA....f.m6.c3.UskB....j....Q1...E9Plr/
...U.ydelyjeYFnzTeOgzf8No..6nc..zzzz..EizccZWGyD.EdGkxmWcz1..........2k.8.kXWF1.
.sM93P58izv.MmnWK2zwz0..........ZQ13yngbl/..Ec2SRCiwz0UWXas0ubwD.kPLULbh7.A04sZz
oV5S........................mi13GPr1.5U.8.kzzzD.................................
XQV0zDsIbA/.kndRjg/pz0.wQOr9PExD.ctwMy5pQ.A..6hcm0U7Eg..zzlSty7.oQm2.szDSnRo.YXB
b.EzTNwqu0k6Uk/.QsLjuG9.a.l0..bTJyfn.M029..lyxuq60U7Eg..Mw5qyW5.a.l0.kqTJX6n.M02
9..kzFBVJ1U7Eg.....crI0.zzFoTu2.yzngi84.xzZX.45.................................
E....I....U/....2....A....EEh3aSdtqNU6oPs/.IjR5.......................k/9.......
..........kYNaNaNaBxzcNaNaNaNavDLD8Qxckpjz1.....................................
.....................6.....3....1....2YEjVLHjF4BY/EG4B3.aN4.....................
.....................AnAnAnAnAzDaNaNaNaNyz1........sz........UzD........Uz1.....
.....................................wzzzzD.....................................
........................................U.2.....................................
................................................zzzzz1..........................
...................................................6./..........................
.....................................................c....U/....1....MoPgFKOiR46
7t4RU.pPr/......................8..0...........................E........i.A.....
...0./..........................................................................
and 2 oopss no 2 is only as m3p file...but this was about the idea
PostPosted: Tue Apr 24, 2012 10:06 am  (#13)
Wow, those light maps are pretty cool! I'll have to start experimenting.
PostPosted: Tue Apr 24, 2012 10:12 am  (#14)
just a last..do you remember the first in my previous message ?
PostPosted: Tue Apr 24, 2012 10:24 am  (#15)
PS for this effect works if "colors on normal" must be checked in the lighting tab
obviously also "use a map for color object" box should be checked
