It is currently Sun Oct 11, 2026 12:02 pm
 Post subject: Engraver II
PostPosted: Sat Jun 16, 2012 12:12 pm  (#1)
I was able to get Engraver II by AlphaPlugins to work through ShellOut>PaintDotNet.
It will not work with PSPI nor through ShellOut>XnView. :)
I am wondering if anyone was able to get this filter to work through PSPI?
 Post subject: Re: Engraver II
PostPosted: Sun Jun 17, 2012 9:30 am  (#2)
will it work with Gimp?or is it a completely separate program?
PostPosted: Sun Jun 17, 2012 9:54 am  (#3)
I'm assuming from what Rod said that it is a Photoshop filter. If you have PSPI installed, you should be able to run most PS filters in Gimp.
PostPosted: Sun Jun 17, 2012 10:05 am  (#4)
nope,no psp :)
PostPosted: Sun Jun 17, 2012 10:28 am  (#5)
It is a commercial 8bf plug-in for Adobe PhotoShop.
Fortunately their are free programs that will run them.Using ShellOut by Rob A, it is possible to use them through Gimp. :)
So far though i have only been able to use ShellOut, and the free program Paint Dot Net to successfully run the Engraver II plug-in. PSPI does not seem to work for this plugin. Although i have no idea why. XnView also will not run it.XnView normally will run any 8bf file.
PostPosted: Sun Jun 17, 2012 12:04 pm  (#6)
pirate541 wrote:
nope,no psp :)
Try here. http://tml.pp.fi/gimp/pspi.html
