It is currently Sat Oct 10, 2026 3:23 pm
 Post subject: Mandelbulb 1.8.2 realesed
PostPosted: Sat Jul 21, 2012 3:10 pm  (#1)
I love this program...a new version is just available
Compiled for Windows,, BUT runs well with Wine in Linux (and i believe also in Mac, for Linux i am sure for Mac i only heard that should work)
What is new in version 1.8:
- New compiler, new look.
- Transparency option in postprocessing, amount of it in object colors.
- Stereo function is more accurate.
- New diffuse map options for object coloring.
- Saving also the internal image buffer along with M3I.
- Addition option for lighting like intensity for all lights and background
image, usage of downscaled background image for ambient color.
- Drag&drop Png files with internal parameters and textfiles with txt pars
on the main window to open the parameters.
- Added euler angles of camera rotation for editing.
- Direct value input in the navigators parameter adjust panel by clicking on
the value.
- Sphere and Cylinder IFS formulas with inside radius.
- New formulas from Luca.
(free) Download
http://www.fractalforums.com/index.php? ... ew;down=43
 Post subject: Re: Mandelbulb 1.8 realesed
PostPosted: Sat Jul 21, 2012 3:20 pm  (#2)
Cheers PC, I've yet to play with this tool, but seen some nice results from it. Thanks for linking :)
PostPosted: Sat Jul 21, 2012 3:37 pm  (#3)
Thank you.
 Post subject: Re: Mandelbulb 1.8.2 realesed
PostPosted: Mon Jul 23, 2012 7:32 am  (#4)
Already updated to 1.8.2 (corrected dl link in the first message )
