It is currently Sun Oct 04, 2026 8:16 am
 Post subject: Fractal4D
PostPosted: Fri Sep 17, 2010 11:52 pm  (#1)
Not too long ago I downloaded Adobe air so i could install Icon Maker Pro for Adobe icons.Well not too long after that i ran into another small program named Fractal4D. Download here http://mac.softpedia.com/get/Graphics/Fractal4D.shtml
You need Adobe air installed first http://get.adobe.com/air/ to run this program, but it's really cool.
Here is an image i created with it.
The fractal follows your mouse pointer wherever you drag it.Click at a point and the fractal stops drawing.
Sort of like finger painting with fractals.You can record like a movie and it saves it in your options under recordings.and export your file to Illustrator. You can even create with layers.
However it won't save as a image extension, I can't seem to figure out how anyways, but any screen capture tool will work to make a png,jpeg, or gif file.I use FastStone Capture.It isn't free (about 20.00 usd), but works rather well for every thing i need in a screen capture tool.
You can use any color bg or fg and it's free, as is Adobe air installer.
Pretty cool program. =)
Here are some other freebies.
http://www.softpedia.com/progDownload/F ... 75573.html <--you need cygwin for this install http://www.softpedia.com/progDownload/C ... 14672.html
http://www.softpedia.com/progDownload/F ... 97910.html
 Post subject: Re: Fractal4D
PostPosted: Sat Sep 18, 2010 12:17 am  (#2)
I take that back it auto saves the image to your desktop, wonder why it doesn't let you choose where you want to save it....strange.
PostPosted: Sat Sep 18, 2010 7:35 am  (#3)
I tried cygwin twice and never got it to work right.
PostPosted: Sat Sep 18, 2010 9:03 am  (#4)
Very Cool ...
PostPosted: Sat Sep 18, 2010 11:00 am  (#5)
Is there any way you can get fractal 4d for Windows XP? :puzzled
Use Gimp for what ever you would like. Creativity has no borders.
PostPosted: Sat Sep 18, 2010 1:45 pm  (#6)
That is running on Windows XP you just have to have Adobe air installed first.You don't need cygwin for Fractal4D, you only need that for the Flames fractal maker, which i tossed aside because it needs a cmd window to run.I hate doing that.
download adobe air, install it
download Fractal4D and adobe air will install it for you. =)
easy as pie.
PostPosted: Sat Sep 18, 2010 3:45 pm  (#7)
I would love somethink alike in Gimp as a painting tool
PostPosted: Fri Oct 08, 2010 5:48 pm  (#8)
Fractal4D + Simple _centre tile
PostPosted: Sat Oct 09, 2010 8:04 am  (#9)
Very nice combination PC! =)
