It is currently Tue Nov 17, 2026 5:59 am
 Post subject: Hot Spot Studio
PostPosted: Mon Sep 27, 2010 11:11 pm  (#1)
Here is a nice little freebie program that I just found and thought I'd share. It's called "Hot Spot Studio", it's actually pretty simple to use and you can get it here http://www.rlvision.com/. I just wish you could save your settings.
Here is one of my images from it:
Then I pulled it up in Gimp, ran GMIC filter on it a couple of times, and tehndid a map to sphere on a squared duplicate of the image, which I put back on it.
My Sigs = My Photos
 Post subject: Re: Hot Spot Studio
PostPosted: Mon Sep 27, 2010 11:17 pm  (#2)
That does look cool PM. About to check it out. Thanks for the link. :)
PostPosted: Tue Sep 28, 2010 7:52 pm  (#3)
really cool pic!
