It is currently Sat Oct 10, 2026 8:14 am
 Post subject: Magix FunPix Maker =)
PostPosted: Wed Nov 03, 2010 11:48 am  (#1)
Loads of fun and free...
Its a warping tool that warps an image in all sorts of different ways.
original default image that comes with the program..
my warping effects. =)
download it here, you have 7 days to register it then it will quit working
http://www.filetransit.com/download.php?id=78854
registering is free of course, just go to the site after you setup a login
https://www.magix.com/us/support/my-ser ... istration/
and enter your email and pass to log-in, click on proceed and follow directions.
You can also go directly to the site and dl it here
http://www.magixphotowidgets.com/category/funpix-maker
if you register and then dl it i think they will send you a code right away. =)
Enjoy!
 Post subject: Re: Magix FunPix Maker =)
PostPosted: Thu Nov 04, 2010 7:14 pm  (#2)
Works very well in Linux, using Wine.
PostPosted: Thu Nov 04, 2010 9:49 pm  (#3)
Is it like using photobooth in mac?
PostPosted: Fri Nov 05, 2010 5:17 am  (#4)
Thanx Rod. got it and registered. Very cool and easy to use.... woo hoo. :wh
PostPosted: Sat Nov 06, 2010 9:42 am  (#5)
I do not know what that is, but its a great free source warping tool. =)
PostPosted: Sat Nov 06, 2010 9:56 am  (#6)
I was going to check the file for nasties but I didn't even get to the download before I got this: http://www.siteadvisor.com/sites/filetransit.com
Be careful people. Please, be careful.
PostPosted: Sat Nov 06, 2010 11:41 am  (#7)
Mine is fine. I just scanned it with Avast and came out with 0 threats......
PostPosted: Sat Nov 06, 2010 1:53 pm  (#8)
To me seems everything safe simply the sude as many other offering freeware and shareware, host also some adware/nagware
(you know that programs that pop out advices about the pro version be much better, and are simply created to push to buy the pro version)
But no problem for program, neither for others
simply betweens the tons of programs and links hosted there are 3 are somehow connected with ww.zangocash.com that has a quite bad reputation
i used only 2 w in the url so nobody may click the link for accident
PostPosted: Sat Nov 06, 2010 2:40 pm  (#9)
Anyway to summarize :
Magix FunPix Maker is clean no harm will come to dl and install
even all other programs on the side are clean but for 3 suspect
atrackseraser_trial.exe : Generic trojan
dmxv10.exe : Generic Dropper trojan, Artemis (artemis is a adware )
sort_music_pro_setup.exe : New Malware.ix trojan
Not that is sure that those 3 contain malware, but is possible
PostPosted: Mon Feb 21, 2011 11:37 pm  (#10)
Quit working in Wine. Bleh. Maybe that's a good thing, maybe not...
PostPosted: Tue Feb 22, 2011 2:47 am  (#11)
Mine still works fine.
Maybe wine updated, and no longer supports MAGIX?
PostPosted: Tue Feb 22, 2011 3:21 pm  (#12)
This is built into Xara Extreme but having a stand alone version will be very handy. Thanks, Rod
PostPosted: Wed Feb 23, 2011 4:27 am  (#13)
I now use Paint Dot Nets Liquify filter through the ShellOut.py script Rob A created. :)
It has a nice big preview screen and many toys to play with like MAGIX.
And it's FREE which is always good.
PostPosted: Wed Feb 23, 2011 5:45 pm  (#14)
Former Member
lol nice!
PostPosted: Tue Jun 19, 2012 4:43 am  (#15)
Thankyou for this recommendation Rod ! Lot's of fun and so simple. :D
PostPosted: Tue Jun 19, 2012 10:01 am  (#16)
I just installed the latest version. Still works really good for me. :)
PostPosted: Wed Jun 20, 2012 4:27 pm  (#17)
New version?
i can't even found a link for the old it seems removed , where you found a newer version ?
PostPosted: Wed Jun 20, 2012 7:31 pm  (#18)
I just tried the link and got a 'Domain Expired' page. :(
Also, the program doesn't/didn't work under Windows 7, only NT through Vista.
PostPosted: Wed Jun 20, 2012 7:55 pm  (#19)
Really?
The link seems to work for me.
PostPosted: Wed Jun 20, 2012 10:43 pm  (#20)
Several links to it worked for me. I attached it in case you just can't download it. Be careful with cnet's version as it will install other garbage unless you tell it not to.
