It is currently Wed Oct 07, 2026 8:36 pm
 Post subject: Batch compression freeware
PostPosted: Thu Apr 25, 2013 12:11 am  (#1)
I wanted to batch zip my scripts so i could use them in MrQ Manager for scripts so i installed 7zip batch.This is what i used when i ran windows xp last year.Well i ran the software and it seemed to run fine but no zipped file output.So i searched for something that would work in windows vista and found this little gem. :bigthup
ArcThemAll.It also gives you a choice of where the output zipped files are stored.I am pretty happy with this freebie.
Just wanted to share in case anyone out there needs a batch compression utility for windows vista.
http://sourceforge.net/projects/arcthemall/ (windows)
 Post subject: Re: Batch compression freeware
PostPosted: Thu Apr 25, 2013 6:57 am  (#2)
Can you help me about MrQ Manager for scripts? Where can i download this manager? Thanks.
PostPosted: Thu Apr 25, 2013 7:13 am  (#3)
You can place all these in your plug-ins folder or just put in the ones you want. Your user/name/plug-ins.
Marek-Basic manager additives.7z [3.04 KiB]
Downloaded 100 times
PostPosted: Thu Apr 25, 2013 7:20 am  (#4)
@molly, but that archive only has the following plug-ins:
MrQ-Brush_Manager.py
MrQ-Fonts_Manager.py
MrQ-Gradients_Manager.py
MrQ-Paletes_Manager.py
MrQ-Pattern_Manager.py
I don't see anything about managing scripts.
PostPosted: Thu Apr 25, 2013 7:35 am  (#5)
Molly thanks, i downloaded your file but Mrq-Scripts_Manager.py is missing? I want organize all scripts downloaded from gimpchat and others..
Saulgoode is right.
PostPosted: Thu Apr 25, 2013 8:37 am  (#6)
You can get the python module for loading zipped SCM files here.
viewtopic.php?f=9&t=4371#p54313
See how much cleaner the menus look now.You locate it in the same sub menu as refresh-scripts.
You have to have all your scripts zipped for it to work though.
And remove all the unzipped ones to a safe folder.For instance i moved mine to a folder on my desktop named Gimp-Files
PostPosted: Thu Apr 25, 2013 8:56 am  (#7)
Saulgoode is right.
Very sorry, :oops: :oops: I should have opened the compressed folder, I was sure the script one was in there. I must have removed it cuz I knew I would never use it. Maybe someone else still has it.
PostPosted: Thu Apr 25, 2013 9:44 am  (#8)
I don't know for sure if there is such a thing as a MrQ Script manager?
You could enable GURM's script manager only and use the MrQ Manager's (fonts, patterns, gradients, palettes) for the rest.
PostPosted: Thu Apr 25, 2013 10:35 am  (#9)
look up about 3 posts - lol :rofl --- viewtopic.php?f=22&t=7070#p89443
PostPosted: Thu Apr 25, 2013 10:38 am  (#10)
The scm files do not have to be zipped to work BUT if you do not zip them they need to be in separate folder
(lots of work).
PostPosted: Thu Apr 25, 2013 12:01 pm  (#11)
I guess along with the mind, the eyesight is going too :blind
PostPosted: Thu Apr 25, 2013 12:23 pm  (#12)
Don't feel bad Odin i be blind too. :bigthup :cu
PostPosted: Thu Apr 25, 2013 12:52 pm  (#13)
Saulgoode is right.
No worries molly, thanks for all others files. :tyspin
http://www.gimpchat.com/viewtopic.php?f=9&t=4371#p54313
Thanks Rod, :tyspin
Thanks Odinbc for your answer.
GimpChat is an awesome forum :jumpclap
