It is currently Fri Oct 09, 2026 11:25 pm
 Post subject: Virtualbox
PostPosted: Sat Jul 20, 2013 6:47 pm  (#1)
Bonjour,
Here are two virtual machines Linux Mint 15 “Olivia” Xfce running under VirtualBox (with Gimp 2.9.1 and Gimp 2.8.7)
64-bit
Translation
http://translate.google.com/translate?s ... 6t%3D10315
Français
http://www.gimp-attitude.org/forum2/vie ... 65&t=10315
32-bit
Translation
http://translate.google.com/translate?s ... 6t%3D10314
Français
http://www.gimp-attitude.org/forum2/vie ... 65&t=10314
 Post subject: Re: Virtualbox
PostPosted: Sat Jul 20, 2013 10:02 pm  (#2)
Nice of you to provide this. :bigthup
Virtualization gives us lots of flexibility. It seems that no matter how much power I have, I always seem to want to use it all for the task at hand. On a client, there is a price to pay for virtualization, in terms of resources.
PostPosted: Sun Jul 21, 2013 6:42 am  (#3)
:tyspin GnuTux
Here's a little video with Gimp 2.9.1 (VirtualBox) and the new tool "Warp Transform"
http://www.aljacom.com/~gmic/New_tool_W ... 130720.ogv
Volume : (10 309 492 bytes) - VLC can play this video.
PostPosted: Sun Jul 21, 2013 9:03 am  (#4)
I'm typing this now in my Virtualbox XP samj. lol
Big fan of Virtualbox; even have a 64-bit version of Ubuntu for one of my VMs. :)
PostPosted: Sun Jul 21, 2013 10:35 am  (#5)
Warp Transform is already there in 2.9, excellent! :gimp
I see still have work to do porting the filters to GEGL, but the work is quite advanced. Version 2.10 will be a great release!
samj, thank you very much for taking your time to do these VM and share them.
Edit.
GnuTux, the dancer Tux is very funny :mrgreen:
PostPosted: Tue Jul 23, 2013 7:00 am  (#6)
Bonjour,
:tyspin Lylejk & YAFU
For fun and back to the first Linux distribution that I used here is a 64-bit virtual machine GimpEval 20130722 version of Debian Linux (VirtualBox)
This version seems faster...
This version of GimpEVAL 20130722 is built on a Debian Linux distribution
* ISO: debian-7.1.0-amd64-netinst.iso
* OS Language: English
* Keyboard: French Canada QWERTY (editable)
Installed programs are:
* VirtualBox Guest Additions
* Gimp 2.8.7 (French and English)
* Gimp 2.9.1 (French and English)
* G'MIC-1.5.7.0 beta for Gimp 2.8.7 & 2.9.1
* Babl
* Gegl
* Glib-2.37.4
Download:
http://www.aljacom.com/ ~ gmic/GimpEVAL-20130722-64bits.7z
(1 627 242 777 bytes) / MD5: fd6eec0843ecb0e9902ab6e209e3c507
2 Users:
* Debian login: root
* Password: roottoor
* Debian login: gimpeval
You can add programs using Synaptic.
Translation :
http://translate.google.com/translate?s ... 722-64bits
Français :
http://www.aljacom.com/~gmic/index.html ... 722-64bits
PostPosted: Tue Jul 23, 2013 12:41 pm  (#7)
# Samj:
Bonjour,
Only a question:
As you yet implement Guess Additions, I wouldn't have to install it when I'll install Virtual Box?.
I will install your Deb VM on Point Linux (Debian 7 based) and Fedora 17.
Thanks.
PostPosted: Tue Jul 23, 2013 1:30 pm  (#8)
samj, thanks again!
Regarding the Debian 64-bit version. The user "gimpeval" not automatically logged in, Should be that way?
Also I can not mount the flash drive, I get message: "failed to mount - not authorized"
I found the following report, but it seems old:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=623496
For those unable to mount the pendrive, open the terminal and type
su
type the password:
roottoor
and mount the device independent file system:
mount /dev/sdb1 /media/cdrom0
PostPosted: Tue Jul 23, 2013 1:37 pm  (#9)
@jamac4k
The "guest additions" are installed on all versions I propose.
If you want to create a "Fedora" virtual machine with the "guest additions" :
- install gcc kernel dkms make bzip2 + drive guest additions + ./VBoxLinuxAdditions.run
- careful if you want to compile Gimp 2.9.1 , "yum" works very poorly on the latest version of Fedora.
PostPosted: Tue Jul 23, 2013 1:44 pm  (#10)
@YAFU
The "Debian" version is created by hand with a minimum of programming. My goal was only to compile Gimp.
You can create more complete versions by choosing a desktop during installation :)
You can log in as root directly if you wish.
PostPosted: Thu Jul 25, 2013 6:09 pm  (#11)
Am I correct that the foreground select tool and the seamless clone too are not functional yet in 2.9.1?
