It is currently Fri Oct 09, 2026 8:22 pm
 Post subject: Collapsed piece of rocks
PostPosted: Thu Aug 01, 2013 3:57 am  (#1)
Hello. This is a collapsing piece of rocks created from Cell Fraction and Rigid Body on Blender 2.6.8 Internal
http://player.vimeo.com/video/71489883
Late 2017 iMac Retina 4K 21,5 inch Mac OS High Sierra version 10.13.4
3,6 GHz Intel Core i7
16 GB Ram 2400 MHz DDR4
Graphic card Radeon Pro 560 4096 MB
Affinity Photo and Affinity Designers.
 Post subject: Re: Collapsing piece of rock
PostPosted: Thu Aug 01, 2013 7:02 am  (#2)
Impressive... do you design the internal veins or are they just made up by the software when it produces a new piece?
PostPosted: Thu Aug 01, 2013 8:48 am  (#3)
Awesome.
PostPosted: Thu Aug 01, 2013 9:30 am  (#4)
Thanks both of you.
Yes, You can design your own. If you have noise on 0, then you will get only the subdivided blocks ( 8 ) lying on each other in this case.
PostPosted: Thu Aug 01, 2013 11:12 am  (#5)
Wow!
Very nice...Impressive! xd
