It is currently Sat Oct 10, 2026 4:24 pm
 Post subject: Blender made Flower
PostPosted: Fri Aug 16, 2013 4:13 pm  (#1)
Hello. Here is one flower made in Blender Cycle.
Late 2017 iMac Retina 4K 21,5 inch Mac OS High Sierra version 10.13.4
3,6 GHz Intel Core i7
16 GB Ram 2400 MHz DDR4
Graphic card Radeon Pro 560 4096 MB
Affinity Photo and Affinity Designers.
 Post subject: Re: Bender made Flower
PostPosted: Fri Aug 16, 2013 6:19 pm  (#2)
Really nice! The flower and the leaves too.
PostPosted: Fri Aug 16, 2013 6:52 pm  (#3)
Really nice. The lighting on the vase is very good. :)
PostPosted: Fri Aug 16, 2013 8:13 pm  (#4)
Nice job!
Leaves look awesome, the petals too, especially their semi-transparency (SSS?).
A few suggestions, if I may.
Stamens look almost plastic, maybe try additional/different shaders.
Vase - good job on ceramics material, but its neck looks cut out. Try additional source of light to get the vase in all its beauty.
I would go with HDRI instead of light emitters (planes).
Checkerboard floor looks weird, don't you think?
Thanks for sharing.
 Post subject: Re: Blender made Flower
PostPosted: Sat Aug 17, 2013 4:19 pm  (#5)
Thank you guys.
I deleted 2 out of 3 emitted plans and add HDR.
PostPosted: Sat Aug 17, 2013 4:53 pm  (#6)
Lurifax73 wrote:
Thank you guys.
Could you retain the same cam position as in the first image?
How did you add HDRI, because it doesn't look like you did [unless the scene is on the bottom of a well].
World->Use Nodes-> Color -> Environment texture -> Open image -> pick your HDRI?
With HDRI you may need no other sources of light since the image itself (bright pixels on it) is lighting up the scene.
Edit. I'd like to play with your blend file, can you, plz, upload it on PasteAll?
PostPosted: Sun Aug 18, 2013 2:58 am  (#7)
K1T
Sounds interesting. Look through my blend file .
World - Enviroment textur - Open Image . I got confused . My table did not fit in with forest enviroment. I tested several HDR. I was looking for a non motive HDR.
http://www.pasteall.org/blend/23499
Thanks for helping.
