It is currently Sun Oct 11, 2026 9:58 am
 Post subject: Help for Tupi.
PostPosted: Mon Sep 02, 2013 12:47 pm  (#1)
Tupi runs a fundraiser on Kickstarter to boost development
http://libregraphicsworld.org/blog/entry/tupi-runs-a-fundraiser-on-kickstarter-to-boost-development
Has anyone attempted to build for Windows?
Question to the experts QT (Mattia Basaglia or Rod):
What is the one mistake?
 Post subject: Re: Help for Tupi.
PostPosted: Tue Sep 03, 2013 11:23 am  (#2)
I think QT 5 creates a problem - is to be used QT 4 ?
[http://qt-project.org/wiki/Transition_from_Qt_4.x_to_Qt5]
Qt::escape is deprecated
    error: 'escape' is not a member of 'Qt'
So you would change the following block:
        if (result == QString())
            result = Qt::escape(val.toString());
        else
            result = Qt::escape(result);
        return result;
to
            result = QString(val.toString()).toHtmlEscaped();
        else
            result = QString(result).toHtmlEscaped();
        return result;
Someone tried to compile Tupi - in Linux ?
With what result ? In what version of QT ?
PostPosted: Tue Sep 03, 2013 1:12 pm  (#3)
Hi MareroQ. I have not tried to compile this for Windows with QT. Where did you obtain the source?
Is it available at GITHUB?
PostPosted: Wed Sep 04, 2013 10:47 am  (#4)
Last Change - 2 months ago.
https://github.com/xtingray/tupi
PostPosted: Wed Sep 04, 2013 10:55 am  (#5)
Hi Marero! I read about Tupi. My understanding is that the devs recomment to build with Qt 4.7 exclusively.
So whoever tried to compile it with Qt 5 made a mistake.
The devs also say that the current git version is under intensive development and they are releasing updated version every week.
Compiling every week is quite a commitment for anyone.
Tupi team has some interesting ideas but so far they remain to be just exactly that, the ideas.
If you need vector based 2D animator today - Synfig Studio is well known to 2d animators free OSS with well established legacy.
PostPosted: Wed Sep 04, 2013 11:24 am  (#6)
Thanks for Your comment and clarification.
I will try with QT 4.7 - on the weekend (but I think I'll start with Linux - Ubuntu
http://www.maefloresta.com/portal/lucid)
