It is currently Wed Oct 07, 2026 8:04 pm
 Post subject: ChangeImage using Linux
PostPosted: Wed Oct 09, 2013 4:58 am  (#1)
For linux users.
Molly raised the subject of this little utility, 'ChangeImage'. http://registry.gimp.org/node/25571 It is a standalone windows application and not a Gimp script/plugin but it does make nice Gimp .ggr gradients.
A very quick demo of calling this from Gimp using RobA's Shellout script.
http://youtu.be/AfWVoYBmIok
caveats:
This is 32 bit linux - PClinuxOS
I never managed to get Shellout greater than ver 0.5 to work in linux
Using WINE ver 1.4 , I found the latest ver 1.6 breaks several of my win utilities so I reverted back.
note on youtube
If you can not hear any audio and/or the video is very small, not my fault, it is youtube flash settings
adjust the youtube player
 Post subject: Re: ChangeImage using Linux
PostPosted: Wed Oct 09, 2013 5:17 am  (#2)
That is great Rich. Glad you got to use it, I don't think anything beats that utility, I also like the way you can see as you go the way the gradient is going to work.
When I was using windoze, I was making pictures with frames and I would use that utility to make my frames from a gradient taken from the picture.
I have 64 bit so I don't know if it will work for me, but I recommend it to all Windows users. I haven't even installed wine yet on Fedora19. I haven't found any need for it yet.
Thank you for your research.
