It is currently Fri Oct 09, 2026 5:20 pm
 Post subject: Looking for a Speech to text program
PostPosted: Sun Oct 20, 2013 11:47 am  (#1)
Anybody know some free program that may convert spoken words in text ?
Even with limitations , as the words to be spoken clearly and slowly
 Post subject: Re: Looking for a Speech to text program
PostPosted: Sun Oct 20, 2013 11:53 am  (#2)
Win 7/8 speech recognition? Just type 'speech recognition' in Start menu.
PostPosted: Sun Oct 20, 2013 12:03 pm  (#3)
So simple ?
Yes i may use 7 but i have no MS Office installed (somewhere i read was needed to activate "'speech recognition") , anyway i am going to try
PostPosted: Sun Oct 20, 2013 1:34 pm  (#4)
I have Siri on my ipad and that is speech recognition, works great. As PC says talk slow and make the words clear or you will end up with words you never heard of.
PostPosted: Sun Oct 20, 2013 1:51 pm  (#5)
Dragon Naturally Speaking, if you can find a copy online, works as well as anything I've ever used.
PostPosted: Sun Oct 20, 2013 3:06 pm  (#6)
Windows Accessibility has Speech Recognition to text.
If you don't mind using the Google API in Chrome, have a look at Dictation.
Digital Inspiration has a review, Dictation – Speech Recognition in the Browser.
PostPosted: Sun Oct 20, 2013 3:31 pm  (#7)
Capture2text:
http://capture2text.sourceforge.net/
PostPosted: Sun Oct 20, 2013 4:37 pm  (#8)
Thank for the tips
Do you have first hand experience of use ?
My doubt is for the languages ,
if i feel confident that will work decently for Italian , because even if i have some slight speech defect (= my L sound close to a N , and my R is ...very soft , has not "roaring", ) my pronounce is correct and without dialectal distortions
.. i fear my spoken English quite far from correct ( even if clear for most humans , ...but here maybe is my mimic helps to make it clear ... )
Basically somebody tried to use speech recognition in a foreign language , a language that knows but not perfectly ?
