It is currently Thu Nov 26, 2026 2:01 am
Post new topic Reply to topic  [ 144 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
 Post subject: 3D text using my paths scripts
PostPosted: Sat Oct 25, 2014 2:51 pm  (#1)
- Create your text using the Text tool, then extract the path with Text-to-path. This is going to be the top/front
- Using the Transform tools (Scale/Move, mostly) in "Path mode" generate the path for the bottom/back. It is important that the transforms keep the number of anchors in the paths (they normally do, but if you use other methods, this should be adhered to).
- Use the path-inbetweener script to generate the intermediate paths (about one path per pixel of the maximum distance between the two paths). Generate the paths starting with the bottom/back path, towards the front
- prepare a gradient going from the "back" color to the "front" color (usually, the "back" color is going to be darker)
- set the brush to something small (the 1px brush (which is 3x3) works OK)
- use the stroke-visible-paths script (normally with the "Use gradient" option) to stroke the paths
- this generates hollow letters, you can add top layer, and bucket-fill a selection obtained from the "top" path.
- flatten image if necessary
Scripts are here
Ofnuts-3D Text Tutorial.pdf [48.44 KiB]
Downloaded 804 times
 Post subject: Re: 3D text using my paths scripts
PostPosted: Sat Oct 25, 2014 3:03 pm  (#2)
Nice! :jumpclap
PostPosted: Sat Oct 25, 2014 4:41 pm  (#3)
Cool ofnuts
PostPosted: Sat Oct 25, 2014 6:03 pm  (#4)
Well now that was an adventure. How did you get your gradient to shade your letters like that? I used the color with gradient dynamic and I like the way yours came out better.
I had to stroke each path individually. The stroke visible paths didn't work for me, just made a blob of color.
PostPosted: Sat Oct 25, 2014 6:15 pm  (#5)
Ofnuts can you put it all together in 1 python plugin for 3d text
PostPosted: Sat Oct 25, 2014 7:31 pm  (#6)
I didn't use dynamics (I'm not even sure that they are emulated in the script-induced stroke). stroke-visible-path should work. What were your paintbrush settings? In particular, which brush did you use?
I didn't use anything special as the gradient. One green, and darker green obtained by reducing the Value from same in the Color selector.
PostPosted: Sat Oct 25, 2014 8:28 pm  (#7)
Here are the settings I used and the results. As you can see, I have the brush set at 3px.
PostPosted: Sat Oct 25, 2014 9:09 pm  (#8)
'O' the brush settings have a bug in 2.8 that was fixed in 2.8.14, where the brush selected actually uses it's default size, so you should have used the '1. Pixel' brush
PostPosted: Sat Oct 25, 2014 10:07 pm  (#9)
Still tired from my 360 mile round trip. Very cool stuff ofnuts. :)
PostPosted: Sat Oct 25, 2014 10:43 pm  (#10)
That 3D look is excellent Ofnuts. :) Would be nice to see a python logo filter for it.
PostPosted: Sun Oct 26, 2014 4:56 am  (#11)
Indeed. And you should have more intermediate paths (otherwise there will be gaps). You could also use a slightly bigger brush, but bigger brushes will round off sharp corners.
PostPosted: Sun Oct 26, 2014 8:55 am  (#12)
Please, someone could turn instructions ofnuts in a more accessible tutorial?
PostPosted: Sun Oct 26, 2014 10:17 am  (#13)
I'll give it a try, Carlos.
Finally!
PostPosted: Sun Oct 26, 2014 10:18 am  (#14)
very nice O
PostPosted: Sun Oct 26, 2014 10:20 am  (#15)
Thank you, Molly. I could have probably used a little fatter brush ... I see some of the teal background showing through.
PostPosted: Sun Oct 26, 2014 10:30 am  (#16)
Ofnuts, perhaps you'd consider adding an option in your 'stroke-visible-paths' procedure to fill the paths* rather than stroke them. This would eliminate the spacing problem Oregonian is experiencing and would overcome the brush size bug pre-2.8.14. If the spacing is too great, there would be banding in the result, but at least there'd be no transparency or oversized outlines.
* actually, select from the path and fill the selection; but of course you knew that.
PostPosted: Sun Oct 26, 2014 10:32 am  (#17)
That is the part I like about it. It looks like a transparent type of ribbon.
PostPosted: Sun Oct 26, 2014 11:03 am  (#18)
Carlos, I made a pdf document of the tutorial and put it in Ofnut's first post and also here.
One more try.
Downloaded 362 times
PostPosted: Sun Oct 26, 2014 12:03 pm  (#19)
saulgoode wrote:
Ofnuts, perhaps you'd consider adding an option in your 'stroke-visible-paths' procedure to fill the paths* rather than stroke them. This would eliminate the spacing problem Oregonian is experiencing** and would overcome the brush size bug pre-2.8.14. If the spacing is too great, there would be banding in the result, but at least there'd be no transparency or oversized outlines.
Done. Also added an option to create a single layer. See version 0.3 at the usual place.
PostPosted: Sun Oct 26, 2014 4:24 pm  (#20)
OK, here's the new script in action:
Top left is the "lid" which will fit on either of the others. Top right is stroke, bottom is fill. All done with the same script v0.3.
