It is currently Thu Oct 08, 2026 10:47 am
 Post subject: Simple Ways to make Logos (Beginners)
PostPosted: Sun Nov 09, 2014 6:50 pm  (#1)
ADDING SIMPLE RELIEF
1 Open a new image transparent
2 Choose Font Sans Bold size 100 and write “GimpChat”
3 Click in the little square under the opacity to lock alpha channel
4 Change the Foreground color to dark blue (0d106f)
5 In the gradient tool be sure to have FG to BG (RGB) invert and choose in the shape “shaped (spherical)”
6 Apply the gradient
USING ALSO THE EMBOSS FILTER
2 Choose Font F820-Deco Bold ( or other font Bold) size 100 and write “GimpChat”
4 Go to the gradient tool and choose the gradient Sunrise ( or Yellow contrast) and put the shape mode “shaped(spherical)”
5 Apply the gradient
6 Filter>Distort>Emboss ( 30,45,20)
7 Colors>Colorize(56,59,-11)
 Post subject: Re: Simple Ways to make Logos (Beginners)
PostPosted: Sun Nov 09, 2014 7:17 pm  (#2)
Marcello 4 Change the Background color to dark blue (0d106f) should be- 4 Change the Foreground color to dark blue (0d106f)
PostPosted: Sun Nov 09, 2014 7:22 pm  (#3)
Nice tute Marcello, thanks for sharing.
PostPosted: Sun Nov 09, 2014 8:12 pm  (#4)
Thank you for the correction!! :oops: :oops: :oops:
PostPosted: Sun Nov 09, 2014 8:17 pm  (#5)
how and where do you do the gradient stroke? side to side, up/down, middle out, top down, or ?????
PostPosted: Sun Nov 09, 2014 8:38 pm  (#6)
to apply the gradient, just make a stroke in the image.The direction and the lenght of the stroke don't matter when using a shaped gradient shape.
PostPosted: Sun Nov 09, 2014 8:39 pm  (#7)
Thanks, that helps a lot. I never have understood how to use shaped gradients.
PostPosted: Sun Nov 09, 2014 8:41 pm  (#8)
you are welcome Molly :pengy
PostPosted: Sun Nov 09, 2014 9:08 pm  (#9)
Learn something new, and easy, every day here!!! Thanks to all who share here!
PostPosted: Mon Nov 10, 2014 5:10 am  (#10)
Marcello, a simple and useful tutorial. Thanks for sharing.
PostPosted: Mon Nov 10, 2014 7:13 pm  (#11)
Carlos & 2-Ton : I have appreciate your interest
here is another logo ( font Gretoon and to put color this time I use COLORS>CURVE>CHANNEL RED X30 Y220 CHANNEL BLUE X220 Y30
