It is currently Thu Oct 08, 2026 9:31 pm
 Post subject: Create Mosaics with G'MIC
PostPosted: Tue Feb 15, 2011 12:30 pm  (#1)
OK, here goes. (ref: http://www.gimptalk.com/forum/how-to-ge ... 48488.html)
Download saulgoode's Mean Fill script: sg-mean-fill.scm
Suggestion before starting: Ctrl + T to disable selection Ants (which can slow down everything if enabled; Thanks to RobA for suggesting this trick to me).
Step one: Choose your target, duplicate, and run Filters > G'MIC > Presets/Testing > Lylejk's stencil. Press Apply and repeat a few times, then OK
Step two: Create an additional Fill layer and choose a pattern and run Stencil on that layer too. Repeat Apply a few times, then OK. You'll see why later; I chose Dried Mud for this one).
Set the Top layer to Lighten and merge Down.
Run Stencil on the resulting Layer. Repeat Apply a few times, then OK. Doing this gives you smaller brick sizes (very important).
Run Filters > Distort > Value Propogate (set to Darken) to widen the outlines.
Invert the result for the mask and cut it to clipboard.
Toggle selection Mask and paste it into the target image.
Untoggle the selection mask and run Saul's Script-fu, Filters > Misc > Mean Fill.
Deselect then Dup the result, and blur the lower layer 1 px and duplicate till solid and merge down. This step widens the islands.
Below's the result of everything so far. Hope that helps.
Additional steps for texturizing, but I'm not going to outline those steps. below's my final result. :)
 Post subject: Re: Create Mosaics with G'MIC
PostPosted: Tue Feb 15, 2011 3:36 pm  (#2)
Original image here.
This is a lot of fun. I haven't perfected my technique but still get interesting results.
PostPosted: Tue Feb 15, 2011 3:46 pm  (#3)
Just got back. Thanks for doing this O; it needed to be here as many of you all know why. I do like this result too. Amazing how fun the GIMP can be when you get folks like David (G'MIC), Rob, Saul, Mahvin, PC, yourself and so many others (can't name them all) to share the wealth of knowledge with the masses. Many here already know I do use PS too, but my main editor is GIMP and one of the main reasons is it's comunity of users. :)
PostPosted: Tue Feb 15, 2011 7:49 pm  (#4)
very nice mosaic Oregonian , as if a mosaicist (how are called the arist making mosaics ? ) was looking a cubist paint trought mosaic lens
and good idea repost the tut !!
PostPosted: Tue Feb 15, 2011 9:02 pm  (#5)
Thank you PhotoComix. I, too, wondered how that image would look as a mosaic. I think it improved the painting.
Can you imagine that painting on your wall? Urg! I'd sell it. A genuine Picasso is worth a lot of $$$.
PostPosted: Wed Feb 16, 2011 10:42 pm  (#6)
Lyle, I've been having fun with your stencil filter. This was done using a black and white diagonally striped pattern. I didn't apply the stencil to the image at all.
Original PSP tube
Results
PostPosted: Wed Feb 16, 2011 11:58 pm  (#7)
I like the grated result O. Have to clarify something though. It's only my preset because David kept it for me (he redesigned Stencil and I liked the old way better, so he kept the preset and named it for me). I only wish I could program these cool G'MIC presets like PC and Tom (and of course David). :)
PostPosted: Thu Feb 17, 2011 8:24 am  (#8)
Those look really cool you guys! :)
I will def have to try it sometime soon.
