It is currently Wed Oct 07, 2026 11:46 pm
 Post subject: Easy Image Enhancement
PostPosted: Wed Jan 07, 2015 2:04 pm  (#1)
Here's a simple way I use to enhance an image, that gives nice results which can be done on any image in Gimp. It's not just for photo enhancement, it's also good for subtle overall image sharpening as well.
I suggest applying this enhancement as the last step when working with any image. Above all making sure that you're doing all your working on a copy of the original image. ;)
Before Image AfterImage
 Post subject: Re: Easy Image Enhancement
PostPosted: Wed Jan 07, 2015 2:14 pm  (#2)
Very Nice Wallace
PostPosted: Wed Jan 07, 2015 3:11 pm  (#3)
CT-Gimper101 wrote:
Very Nice Wallace
Thanks CT-Gimper101. :bigthup
It's something I often use to subtly sharpen an image and thought other might find is useful. ;)
PostPosted: Wed Jan 07, 2015 3:24 pm  (#4)
Thank you Wallace. That is very useful and the improvement is noticeable. :hi5 :tyspin
PostPosted: Wed Jan 07, 2015 3:54 pm  (#5)
Thank you Wallace... nice job
PostPosted: Wed Jan 07, 2015 4:37 pm  (#6)
You're welcome Issabella and MollyImage
It's basically like applying a High-pass filter to sharpen the image, but with a bit more subtle of an effect.
PostPosted: Wed Jan 07, 2015 4:58 pm  (#7)
This is great, thanks Wallace! I've been using a similar process, but your method is quicker and I hadn't tried inverting the colors. More ideas to play with, hooray!
Sometimes, for a stronger effect, I'll set the final layer to Grain Merge instead of Overlay.
If the image is noisy and I don't want to sharpen the noise, I'll take the final gray layer and give it a 1 or 2 or 3-pixel gaussian blur. Just enough blur to soften the grainy bits.
This page has some ideas about how much to blur: http://clownfishcafe.blogspot.com/2013/ ... ening.html
This is, far and away, my favorite way to sharpen a photo. I only wish this technique had a name. I've been calling it do-it-yourself highpass sharpening, but I gather this is a little different? What should we call it? Because we really should teach it to everybody.
PostPosted: Wed Jan 07, 2015 5:32 pm  (#8)
It's very similar to a high-pass filter. I haven't really gaven thought to naming it. I guess it could be called a sort of DIY High-Pass.
The blur amount has a lot to do with the image size, but the link you provided does shed some light on the blurring process.
It would be easy to experiment with this to achieve the results one might be after, without relying on filters to hopefully do the job for you.
Some Gimp users may also not know how to apply a high-pass filter, nore have a script/filter installed that does this. It's a simple method that can be used on any image, without the need of a filter.
PostPosted: Wed Jan 07, 2015 5:38 pm  (#9)
Wallace if you want to script this technique it would be very easy
another method is Gmic's 'Split Details' (David asked me to script it for him as it can be complicated to use)
look for Filters/G'MIC GWD (Split Details)
PostPosted: Wed Jan 07, 2015 5:45 pm  (#10)
Thanks Graechan. :bigthup
That's easy for you to say, I'm not a scripter/coder like you. :hehe
I know you have only good intentions, but afterall the point being is not having to rely on a script.
PostPosted: Wed Jan 07, 2015 6:45 pm  (#11)
Works well Wallace... here is my before and after.
Before
After
Thank you Wallace
PostPosted: Wed Jan 07, 2015 6:47 pm  (#12)
Wallace, Cool technique on the homestead.
PostPosted: Wed Jan 07, 2015 7:05 pm  (#13)
This feels eerily similar to Filters>Enhance>Unsharp mask (which under the hood is also subtracting a blurred version of the the image from the original to bring out the high-frequency elements...).
PostPosted: Wed Jan 07, 2015 7:46 pm  (#14)
Thank you Wallace
looking good Molly! :bigthup
Yeah thanks Odin. :)
I couldn't figure out what image to use for the demo, so I used my old childhood home. :hehe
ofnuts wrote:
Could be, I wouldn't doubt it. Only no use of filters.
I wish I could remember where I learned this technique from.
PostPosted: Wed Jan 07, 2015 7:49 pm  (#15)
Yes it does work:
But this is what Unsharp Mask can do:
PostPosted: Wed Jan 07, 2015 8:31 pm  (#16)
jontait2 wrote:
Yes it does work:
Before [ Image ] After[ Image ]
It's quite understandable what Unsharp Mask can do.
I did mention that it was A "subtle overall image sharpening", emphasis on the word "subtle".
However... there is no use of a script when using this so called "DIY High-Pass" technique as described.
PostPosted: Wed Jan 07, 2015 9:27 pm  (#17)
Thank you Wallace. Very nice indeed
It showed a marked improvement on this photo but I still have to get a spot out (unsharp mask) didn't help
Before
After
PostPosted: Wed Jan 07, 2015 9:39 pm  (#18)
Before
After
Image :bigthup
PostPosted: Thu Jan 08, 2015 10:07 am  (#19)
I had to try this method. Here is my try. Photo just cnverted to jpg.
Sunrise 2015-01-07
Original:Image
After Wallace-method:
Thank you Wallace for yor method!
PostPosted: Thu Jan 08, 2015 10:34 am  (#20)
Sunrise 2015-01-07
Original:[ Image ]
No problem Himppu. :bigthup
I really can't claim this technique as my own. I picked it up somewhere, but for the life of me, I can't remember where.
