It is currently Sun Oct 11, 2026 5:52 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Bic pen sketch girl.
PostPosted: Sat Apr 11, 2015 6:44 pm  (#1)
This tut is inspired in this Ps's one.
If you want can get the model resource there.
Enjoy!!.
File comment: Bic pen Sketch girl tut
bic-pen_sketchgirl.pdf [1.68 MiB]
Downloaded 743 times
 Post subject: Re: Bic pen sketch girl.
PostPosted: Sat Apr 11, 2015 7:35 pm  (#2)
Cheers jamac4k.
PostPosted: Sun Apr 12, 2015 9:04 am  (#3)
Thanks Odinbc !!
PostPosted: Sun Apr 12, 2015 9:21 am  (#4)
Thank you Jamac for your tutorial. I've tried to follow it but I am lost at some of the steps of it. The effect is very nice. :) :bigthup :tyspin
PostPosted: Sun Apr 12, 2015 10:20 am  (#5)
jamac 4k Thanks for the nice tut.
I tried the bic pen sketch ,but in my G'MIC I can not found'' SAMJ texture COLOREE ''
PostPosted: Sun Apr 12, 2015 10:26 am  (#6)
@gimper66
pls expand the submenu Artistic under Samj
at the bottom, it's there
PostPosted: Sun Apr 12, 2015 10:48 am  (#7)
@gimper66
that's what I've done, but it is not in the sub menu list
PostPosted: Sun Apr 12, 2015 11:09 am  (#8)
Nice tutorial. Thank you. :)
Inkpen Scribble
font- http://www.dafont.com/search.php?q=inkpen
pen image (my own)
Remove the olive bg by using color-color to alpha-select the olive color in the preview image and click ok. Duplicate the pen layer to your liking. I also used a blue shadow.
Paper texture is from here -
http://registry.gimp.org/node/25382
Settings and color is ede9de
Inkpen signiture color - 08081d - duplicate layer and set top layer to hue mode.
My results
PostPosted: Sun Apr 12, 2015 11:19 am  (#9)
You are using G'MIC 1.6.0.3 with 414 filters, I would consider upgrading to G'MIC 1.6.1.0 with 435 filters.
PostPosted: Sun Apr 12, 2015 11:22 am  (#10)
# gimper 66:
Perhaps is problem of your g'mic version. Mine is 1.6.2.0, yours is 1.6.0.3 as i can see in your screenshot. I don't remember if this filter was allocated in previus versions.
#Issabella:
- abrimos imagen
- la duplicamos y desaturamos (luminosidad)
- duplicamos ésta, invertimos, le aplicamos el desenfoque gaussiano y la ponemos en modo
blanquear
- aplicamos g'mic en modo capa nueva de salida; ponemos esta capa en modo en modo ennegrecer.
- le damos color a esta capa con colores>>> colorizar buscando los tonos azules yjugando con saturación y luminosidad.
- abrimos como capa la textura de papel o creamos una con un patrón. La situamos debajo de la anterior.
- para borrar detalles no deseados añado máscara de capa transparente.
PostPosted: Sun Apr 12, 2015 11:25 am  (#11)
Thank you so much for your explanations, Jamac. I'm going to try it again. :tyspin
PostPosted: Sun Apr 12, 2015 11:50 am  (#12)
Makes a nice result. :3
PostPosted: Sun Apr 12, 2015 1:15 pm  (#13)
With my G'MIC 1.6.1.0 the following two Samj filters, disappear if I do not refresh filters.
Testing / Samj / Artistic / Samj impressions
Testing / Samj / Artistic / Samj texture coloree
PostPosted: Sun Apr 12, 2015 3:17 pm  (#14)
Neat short tutorial Jamac4k - thank you very much :)
Tried the young lady first, then used another favourite character because there would be no need to 'erase/clean up' the image, he is always dirty!
PostPosted: Sun Apr 12, 2015 3:53 pm  (#15)
lol... Is he a troll?
PostPosted: Sun Apr 12, 2015 5:47 pm  (#16)
@Molly - no, that is Tolkien's Smeagol/Gollum from The Hobbit; he is not strictly a 'troll' which has its derivation in Norse mythology. Although Smeagol was a Hobbit, more likely in his Gollum form, he is a 'troglodyte'.
Whatever he is, I just love the character.
And just to prove I did the original tut, but also found a very attractive 'samj granular texture' in the tut's target GMIC section .. here she is
PostPosted: Mon Apr 13, 2015 12:11 am  (#17)
Odin,
for having G'MIC keeping last "refreshes" do the following:
1-install the latest version (1.6.2.0 pre-release)
2-start GIMP
3-refresh GMIC (should show up version 1.6.2.0 pre-release)
4-close GIMP
5-delete file "update1620.gmic" which you find under (user)/AppData/Roaming)
beware: there are two files in that folder:
a)gimp_update1620.gmic WHICH SHOULD STAY THERE
b)update1620.gmic WHICH SHOULD BE REMOVED (move it to your desktop, for safety)
6-restart GIMP, G'MIC should be able to keep all "refreshes"
PostPosted: Mon Apr 13, 2015 2:10 am  (#18)
# gimper 66:
jamac4k
I'm looking for the G'MIC version 1.6.2.0 but have not found yet !!
can someone help me
PostPosted: Mon Apr 13, 2015 2:13 am  (#19)
I have to start saying Thanks to you Jamac, Here is my try. :tyspin
Also Thanks to Dinasset for your help about Gmic. Now it's all right. :tyspin
Fantastic outcomes OMG, like usual in you, you get so nice results. :coolthup
PostPosted: Mon Apr 13, 2015 2:42 am  (#20)
# gimper66:
You must go here.
You can find here the last release for your OS.
