It is currently Mon Nov 30, 2026 7:34 am
 Post subject: How To Paint Hair In GIMP 2.6 and 2.8 [PDF]
PostPosted: Wed Jul 01, 2015 2:08 pm  (#1)
Okay well I said I'd try and make something so this is what I came up with!
Warning: I give instructions terribly so I'm not guaranteeing that it'll make any sense at all. :lol
hair_tutorial_factoid_firefly.pdf [795.42 KiB]
Downloaded 783 times
I hope this is useful for somebody!
~ God Bless ~
~ Moko
 Post subject: Re: How To Paint Hair In GIMP 2.6 and 2.8 [PDF]
PostPosted: Wed Jul 01, 2015 3:16 pm  (#2)
:coolthup
PostPosted: Wed Jul 01, 2015 3:58 pm  (#3)
Mokonafan - :bigthup
Good one - this old guy is almost bald (despite the avatar) so now I can add hair to all my photos!!
PostPosted: Wed Jul 01, 2015 6:58 pm  (#4)
Thanks for sharing Moko. Hair is something I do have a lot of problems with. BTW, the brush you used, I don't believe I have that one. Is that one of the Gimp defaults? It looks like it could be very helpful.
I will be sure to do this one.
PostPosted: Wed Jul 01, 2015 9:38 pm  (#5)
:tyspin :tyspin :tyspin
You're welcome, I hope it helps!
It's not a default, I think I got it in a brush pack for gimp. Which one I'm not sure, it might be Gimp paint studio addon thingy.
PostPosted: Thu Jul 02, 2015 3:00 am  (#6)
moko: good job on that tutorial, thanks for sharing.
PostPosted: Thu Jul 02, 2015 4:01 am  (#7)
Nice one! Thank you very much Moko - this'll be useful.
PostPosted: Thu Jul 02, 2015 5:01 pm  (#8)
No problem! I hope it helps. :D
PostPosted: Fri Jul 03, 2015 5:26 am  (#9)
Simple and very useful. I added some of my own techniques at the end so that it worked with my style. I'll need to practice more as well.
PostPosted: Fri Jul 03, 2015 5:36 am  (#10)
Wow, nice job Eris. What did you use as a brush. I was hoping to get the one moko used before I tackled it
PostPosted: Fri Jul 03, 2015 12:42 pm  (#11)
GPS has a brush called Scratches. I used that one.
PostPosted: Fri Jul 03, 2015 12:50 pm  (#12)
Thanks Eris, can you share it... I don't think I have it.
PostPosted: Fri Jul 03, 2015 2:16 pm  (#13)
Nice! Thanks for trying it! :D
I don't know where to get these brushes anymore so I made a zip of some of them.
brushes.zip [1.72 MiB]
Downloaded 233 times
PostPosted: Fri Jul 03, 2015 2:41 pm  (#14)
Thank you Moko, is that pencil scratch brush the one you used?
PostPosted: Fri Jul 03, 2015 5:08 pm  (#15)
No problem. I used Bristles 1.
