It is currently Mon Nov 30, 2026 1:46 am
 Post subject: Frosted Glass Effect by hand (pdf from trandoductins orignal post)
PostPosted: Tue Sep 08, 2015 1:56 am  (#1)
Reposting this tutorial here in pdf form. The original tutorial can be found at the original thread in these forums.
FrostedGlassEffect-trandoductin-1.0.pdf [1.91 MiB]
Downloaded 1577 times
(Solve if you can ... ;) )
 Post subject: Re: Frosted Glass Effect by hand (pdf from trandoductins orignal post
PostPosted: Tue Sep 08, 2015 5:44 am  (#2)
Thanks jazzon. :bigthup
PostPosted: Tue Sep 08, 2015 11:39 am  (#3)
good job on the pdf. Thank you!
PostPosted: Tue Sep 08, 2015 8:48 pm  (#4)
I used G'MIC>Deformation>Water to make the texture. I also sharpened the text a little.
PostPosted: Tue Sep 08, 2015 8:58 pm  (#5)
man that gold looks pretty good. much better than mine
PostPosted: Tue Sep 08, 2015 9:13 pm  (#6)
I did followed your tutorial, except for the texture and the sharpening of the text.
PostPosted: Wed Sep 09, 2015 11:55 am  (#7)
Did you just skip the texture creation steps...and sharpened the masked text layer then?
PostPosted: Wed Sep 09, 2015 1:24 pm  (#8)
Well Trandoductin, that's not exactly what I did.
I didn't skip the texture step, I only used a different method for creating it. I also didn't want to search around for the right texture to use.
The sharpening of the text was a step added toward the end.
I think it worked out well.
