It is currently Fri Nov 27, 2026 5:01 pm
 Post subject: Batman Logo Tutorial
PostPosted: Thu Oct 01, 2015 2:25 pm  (#1)
I have finished this Batman logo tutorial that I started late last year. It's in PDF format.
The .zip file won't upload here, perhaps it's too big. Link for download:
http://s000.tinyupload.com/download.php?file_id=31684869627416748296&t=3168486962741674829635870
 Post subject: Re: Batman Tutorial (PDF) Preview: Feedbackback required
PostPosted: Thu Oct 01, 2015 2:56 pm  (#2)
I found a typo, look here...
So far it looks like a good start.
PostPosted: Thu Oct 01, 2015 3:43 pm  (#3)
For Windows and Adobe Reader, the quality very good.
PostPosted: Thu Oct 01, 2015 4:06 pm  (#4)
The PDF renders fine in all viewers I tried.
I normally use OfficeLibre to make PDF documents, Abiword might have some of the same features.
  1. To have the actual tutorial title (not the file name) show in a PDF viewer, in document properties add the title and optionally author, date, etc. I don't think Abiword does that on PDF export.
  2. In OfficeLibre, when you use proper heading styles in a document, H1, H2, etc., export as PDF it automatically create a headings bookmark index for navigation. Abiword doesn't do that either.
  3. If you're planning a screen only PDF image resolution is not an issue other than PDF file size. If it's primarily for print prepare 300 PPI images. One caveat, if you're primarily designing for screen but images are somewhat crucial (in case someone wants a printed version) 150 -200 PPI should work.
  4. A note on screenshots, use them for visualization not the only way of relaying information like setting. In other words, for accessibility have all screenshot settings duplicated in text.
If you have OfficeLibre I'd give it a go, the PDF export is very good.
I look forward to your finished tutorial! :bigthup
PostPosted: Fri Oct 02, 2015 7:05 pm  (#5)
Windows 8.2 and Adobe Reader 11.0.12 and everything looks fine here.
PostPosted: Thu Oct 08, 2015 4:36 pm  (#6)
Thanks, the typo will be amended in the final tutorial. Still got a long way to go with it.
PostPosted: Thu Oct 08, 2015 4:43 pm  (#7)
Thanks.
I use Puppy Linux (Lighhouse64) and although I've got an Libre Office SFS somewhere, I personally prefer to keep my document apps lightweight, as I don't use them too often. Abiword is just right for my needs.
I've tried viewing my PDF on multiple PDF viewers and they all work fine except Evince. It's still good enough though, I think.
PostPosted: Tue Mar 29, 2016 7:05 pm  (#8)
Completed and updated for download. See original post.
 Post subject: Re: Batman Logo Tutorial
PostPosted: Tue Apr 05, 2016 3:07 pm  (#9)
I would like to try this tutorial but I couldn't access it because apparently the download contained spyware so my computer blocked the download.
PostPosted: Tue Apr 05, 2016 4:04 pm  (#10)
mackenzieh wrote:
I would like to try this tutorial,
but I couldn't access it.
Apparently the download contained spyware,
What's contained in the downloadable archive.zip file is a PDF of the tutorial.
File comment: Batman Logo Tutorial PDF
Batmanlogotutorial-min.zip [3.24 MiB]
Downloaded 377 times
PostPosted: Tue Apr 05, 2016 4:31 pm  (#11)
Thanks Wallace! :) :bigthup
PostPosted: Tue Apr 05, 2016 4:36 pm  (#12)
:coolthup
No problem Mackenzieh.
I guess your computer didn't give my zip file the boot.
PostPosted: Wed Apr 06, 2016 12:54 am  (#13)
:coolthup
No, I downloaded it. :) Thanks again.
PostPosted: Wed Apr 06, 2016 1:11 am  (#14)
Sure thing Mackenzieh. ;)
