It is currently Tue Nov 24, 2026 6:30 am
 Post subject: Setting up your addonCollection Manager Tutorial
PostPosted: Sun Nov 08, 2015 10:48 am  (#1)
Setting up your addoncollection manager is quite simple now since the original Python plug-in has been modified
I will start with the brush manager for this tutorial.
You will need the plug-in that is foundHERE
If you are using Linux, make sure you check execute in the permissions allowing executing file as a program.
original doc. http://gimp-tools.sourceforge.net/managementtools.shtml
Place this addonCollectionManager-3.0.py into your user Plug-ins folder.
Open your .gimp-2.8 folder, right click inside the folder and click Create folder and name it brushes_storage.
What you need to do now is make several folders inside this storage folder. Here is an example of some of mine. Remember to capitalize the folders.
You can make as many folders as you like and add them later if needed.
Now that this folder ready, go to your brushes folder, cut and paste all your brushes into these folders. This is what takes the time trying to sort them out into the proper folders.
Make sure all the brushes are gone out of your brush folder and into your brushes_storage. When you open your gimp, only the brushes you have selected will show in your brushes. You will be able to tick beside all the brushes you want to open.
When this is done, open your gimp and right click on your brushes and you should see brush sets.
Click the brush sets and another window will open and all your brushes will be in view that you put in the alternate folder, Click beside the brushes you want to open and brush manager will open those and click ok
All your Gimp default brushes will be in with your brushes so you don't have to load them because they will already be there,
TIP... The reason you will be emptying your brushs folder is so that just the brushes you have selected will go there. If you untick those brushes in your brush manager, they will go back to your brush manager and that brush folder will be empty again. So, the only brushes you will see in your brushes folder are the ones you have selected and the default brushes
Please, any questions, post here or pm me.
 Post subject: Re: Setting up your addonCollection Manager Tutorial
PostPosted: Sun Nov 08, 2015 7:06 pm  (#2)
Great tut, Molly. I actually renamed the Original folders and made new Default folders. I saved time not having to copy/paste. The internal folders were a nightmare but I have got some good ideas from looking at yours.
PostPosted: Sun Nov 08, 2015 7:54 pm  (#3)
Thank you kimba, I also used it for my fonts, but there is just too many of them to sort and name.
PostPosted: Mon Nov 09, 2015 2:58 am  (#4)
Thank you Molly for your tutorial. I'm sure your useful tut will help many members here. :tyspin :)
PostPosted: Mon Nov 09, 2015 6:47 am  (#5)
you are welcome issabella
PostPosted: Fri Sep 16, 2016 9:20 am  (#6)
Thankyou Molly, that's the clearest explanation I've found so far. One thing I'm unsure about, you posted - "TIP... The reason you will be emptying your brushs folder is so that just the brushes you have selected will go there. If you untick those brushes in your brush manager, they will go back to your brush manager and that brush folder will be empty again. So, the only brushes you will see in your brushes folder are the ones you have selected and the default brushes"
Question; As I'm emptying my C/User/Me/GIMP2.8 brushes folder completely, does the AddOnManager somehow automatically detect the GIMP default brushes after I've put my made brushes folders in AOM, or do I have to make a folder for them as well?
PostPosted: Fri Sep 16, 2016 9:23 am  (#7)
default brushes are in Program Files/....., not in User folder, and it's Gimp which detects them not the AddonCollectionManager
PostPosted: Fri Sep 16, 2016 11:03 am  (#8)
Please be patient - one (hopefully) last question. Where, exactly, am i creating the storage folder within my GIMP directory?
PostPosted: Fri Sep 16, 2016 11:27 am  (#9)
if you do not need to use those folders for more than one user, place them under:
C:\Users\yourname\.gimp-2.8
PostPosted: Fri Sep 16, 2016 11:34 am  (#10)
brushes_storage goes in [USER]/.gimp-2.8/
In the example below I have 'Wilber-obc.gbr' selected in the addon manager.
~/.gimp-2.8/
├── brushes
│   └── Wilber-obc -> /home/odinx/.gimp-2.8/brushes_storage/Wilber-obc
├── brushes_storage
│   └── Wilber-obc
│       ├── Wilber-obc.gbr
Using Linux paths.
PostPosted: Fri Sep 16, 2016 11:56 am  (#11)
Just to add to Odinbc,
The folder structure is
Just make sure the brushes/fonts/scripts/patterns....in each something_storage
are in sub-folders or zipped.
edit: Still not so clear. You can of course have more than one sub-folder or zip file or combination of each
PostPosted: Fri Sep 16, 2016 1:41 pm  (#12)
I've learned so much from installing AOCManager, I now have a basic grasp of filing (used to baffle me) and I'm obsessed with inventory. A huge thank you to all who have guided me through this. :yes
PostPosted: Sun Dec 22, 2019 10:34 pm  (#13)
I have the addonCollection Manager but which folder do I go to for the brushes? It is both folders? I'm on Windows 10 64 bit.
PostPosted: Mon Dec 23, 2019 12:04 am  (#14)
Program Files/GIMP 2/share/... folders should be reserved to Gimp itself.
The user deals with User/... folders.
Having addonsCollectionManager the user adds new folders under .../brushes_storage, then manages her/his collection using aCM to "activate" (or "deactivate") them, which means aCM will copy (remove) into (from) ...brushes.
PostPosted: Mon Dec 23, 2019 12:28 am  (#15)
Oh, okay. The reason I asked is because sometimes the User folder doesn't read the brushes and the share folder does.. that's where I have folders of brushes.
PostPosted: Mon Dec 23, 2019 9:03 pm  (#16)
All your 3rd party brushes, gradients plugins, scripts, etc... should go in your users GIMP 2.10 folder. Looking at the image you provided, you should move your addons to the User folder. Don't mess around with the Program folder "GIMP 2" and don't add anything there. This is how you User GIMP 2.10 should look:
When you create the folder for the addOnCollectionManager plugin, you folders should look like this . You Have to create an individual "_storage" folder for this items:
1. brush_storage,
2. dynamics_storage,
3. fonts_storage,
4. gradients_storage,
5. patterns_storage
6. scripts_storage.
Then create sub-folder and re-name them according to the set of the items. For this purpose I chose the brushes_storage.
Start GIMP and right click inside the dialog your going to use. For this purpose I selected "brushes sets". Right click on the brushes dialog and the "addOnCollectinManager" will pop up. Check on any brushes sets to add, or unchecked to remove.
The only addon that is not on the dialog is the scripts. You have to go to, "Help" and select "scripts sets". That is all.
PostPosted: Mon Dec 23, 2019 11:15 pm  (#17)
I found an easier way to add brushes to the storage folder.. it works for any folder really. I suggest brushes you collect, go into folders, then copy those folders and then paste them into the _storage folders.
