It is currently Tue Nov 10, 2026 6:44 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: OMG BRL design tips for glass/wood contours
PostPosted: Thu Nov 26, 2015 3:40 am  (#1)
I was asked to provide some guidance on my design methods for some BRL glass/wood images that possess 'topographical' features - that is possess some 3D characteristics based on surface shape and contours.
The intention is to produce an image like this ...
So hopefully this tutorial will fit the bill - its long and certainly not the only way, but should help 'newbies' and 'neophytes' with the process. If you find any errors or omissions, please advise me.
File comment: Patterns, brushes and emaps used in the tutorial
OMG BRL extras.zip [2.21 MiB]
Downloaded 991 times
File comment: The tutorial PDF
OMG BRL design tips.zip [2.89 MiB]
Downloaded 828 times
 Post subject: Re: OMG BRL design tips for glass/wood contours
PostPosted: Thu Nov 26, 2015 4:45 am  (#2)
Thanks omg, I'm looking forward to seeing this.
PostPosted: Thu Nov 26, 2015 7:10 am  (#3)
PostPosted: Thu Nov 26, 2015 1:24 pm  (#4)
Thank you very much OMG! I won't have time to give it proper attention until after Thanksgiving but then I'll give it all my best efforts!
Thank you again. :roll: :paint :tyspin
PostPosted: Thu Nov 26, 2015 1:45 pm  (#5)
Thank you so much OMG, I'm sure your tutorial will be great help and useful to get good results. :tyspin :clap
PostPosted: Thu Nov 26, 2015 11:52 pm  (#6)
ImageI did it but I have strange gaps in my selections. I also needed to move the layers around a bit.
PostPosted: Fri Nov 27, 2015 12:57 am  (#7)
Kimba - well done and I did say try different blends and move layers around. :jumpclap
Hopefully the tut does/says all the right things and did not cause your problems, but proof reading it, when I already knew what to expect, was a problem for me. :oops:
So anybody whgo finds errors please let me know.
PostPosted: Fri Nov 27, 2015 5:03 am  (#8)
I appreciate and thank your tutorial a lot OMG. I know what a high level you have creating such a great outcome. Thank you so much in spite of the fact my outcome isn't so good as I would have liked, it came something different from yours (sorry). However I've learnt many new steps about paths and that it's important for me. :) :tyspin
PostPosted: Fri Nov 27, 2015 12:32 pm  (#9)
I did my second try, OMG. I experimented as you said with layer modes and changed the centre by adding a gem too. :) :tyspin
PostPosted: Fri Nov 27, 2015 12:37 pm  (#10)
play, play, ladies and gentlemen.....
something creative will come out
you should not only follow OMG tutorial, but also try to vaguely imitate his creativity! hehehe...
PostPosted: Fri Nov 27, 2015 1:46 pm  (#11)
Following Dinasset's advice I did a new outcome. I used some Erisian's maps. :)
PostPosted: Fri Nov 27, 2015 2:09 pm  (#12)
creativity comes out! good!
(BTW, I believe that learning how to change something leads to a better understanding of OMG's ideas, I'm sure he will appreciate your efforts...)
PostPosted: Fri Nov 27, 2015 11:21 pm  (#13)
Issabella - very well done and thank you for trying my 'tut'. I did recommend in the document that you should play and try different things, then both outcomes and learning will flow!
PostPosted: Sat Nov 28, 2015 12:19 pm  (#14)
Thank you OMG, nice tutorial to learn many things. :tyspin
PostPosted: Mon Nov 30, 2015 11:08 pm  (#15)
My attempt at your very precise and well organized tutorial.
I learned so much from following your instructions, even if I have made mistakes. Besides the use of BRL and paths, I have a deeper understanding of the many other tools such as patterns and their variations, brushes, and other incidentals.
Sorry to be a pest, but I have more questions! This is my second attempt. I thought I had misread some instructions but I could not find out where I may have. I do not have well defined circles around the gems as you and others have. Also, I could not get rid of the color from the xmas bells around the gems, center circle and cross. I even tried fixing with re doing the BRL parts on some after growing or shrinking selections but nothing removed the color. I also added a thin ring around the center and the outside circumference as it looked plain compared to yours.
I thought the colors were all correct but after uploading I noticed the small gems look more pink than orange. Any suggestions?
PostPosted: Tue Dec 01, 2015 12:15 am  (#16)
Pat625- that is a really well done interpretation and I am impressed :jumpclap :jumpclap
I am not on my own machine right now to check the tut instructions for any errors. However, as for the 'xmas bells' pattern showing around the BRL glass objects, the only reason I can put forward is that you have left them as visible layers - they only need to be visible if you use them, say in 'overlay' mode.
I will check the tut instructions and get back to you later.
PostPosted: Tue May 10, 2016 9:54 am  (#17)
great tut, thanx OMG. My 'middle bits didn't fill and I didn't get the outside bevel you created, however I very pleased - in Peace
PostPosted: Tue May 10, 2016 11:49 am  (#18)
Huh?! RJKD, thank you for bringing attention to this post; great outcome on your submission. Excited to give it a whirl later today.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Tue May 10, 2016 8:59 pm  (#19)
Totally immersed in this tutorial! Forgot all of life's possible issues for a while ;)
Omg, thank you for a great teaching/sharing tutorial.
I put little diamonds in the little cups - how? I have no idea - wasn't intended followed the tutorial - another happy accident.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Wed May 11, 2016 11:16 am  (#20)
Lovely work Dalia, you got the little diamonds by turning off the BR Logo copy //6 layer (least ways - that's what happens with mine), happy accidents, bit like butterflies - in Peace
