It is currently Sun Nov 29, 2026 9:59 pm
Post new topic Reply to topic  [ 97 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Crystallize an image.
PostPosted: Thu Dec 03, 2015 12:46 pm  (#1)
I've attached a quick and dirty tutorial. Of course, be creative on your own for better results. The attached image has a few additional enhancements (mainly color/sat adjustments). :)
How to Crystallize an image.pdf [798.64 KiB]
Downloaded 1141 times
 Post subject: Re: Crystallize an image.
PostPosted: Thu Dec 03, 2015 12:52 pm  (#2)
Just realized that, on the poly step, you need to set the edge opacity to completely transparent (I didn't state that in the tut and no, I'm not going to re-write it. lol). :)
PostPosted: Thu Dec 03, 2015 1:59 pm  (#3)
Thank you so much Lyle for your tutorial to get such an attractive outcome. I like it a lot. :tyspin :)
I attach your PDF with the missing step. (I hope) if wrong, please tell me. :)
How to Crystallize an image.pdf [563.72 KiB]
Downloaded 763 times
PostPosted: Thu Dec 03, 2015 7:12 pm  (#4)
Image My effort,combined with Conbagui's Chrissie background from Google+. My pine branches now have blue flowers.
PostPosted: Thu Dec 03, 2015 7:35 pm  (#5)
Just discovered changing Blend Mode to Grain merge gives me Snow.Image Thanks Lyle and Issabella.
PostPosted: Thu Dec 03, 2015 11:32 pm  (#6)
Thanks Issabella. Like your result Kimba. Like I sort of inferred, if you set the edge opacity to completely transparent, you can rid the lines. :)
PostPosted: Fri Dec 04, 2015 1:27 am  (#7)
I couldn't see an edge opacity setting so wasn't sure about which setting to change.
PostPosted: Fri Dec 04, 2015 2:31 am  (#8)
Here you go Kimba. :)
PostPosted: Fri Dec 04, 2015 5:19 am  (#9)
Lyle, I like this style yours on pics. Following your tutorial and added a few additional enhancements to get this. :) :hi5 :coolthup
I didn't get your personal touch but I like it. :)
PostPosted: Fri Dec 04, 2015 8:21 am  (#10)
Nicely done Issabella. Another trick to get the Icy colors is to use gradient mapping with the Metallic Something preset. :)
PostPosted: Fri Dec 04, 2015 8:36 am  (#11)
Thank you Lyle, I'll try it using gradient. :)
PostPosted: Fri Dec 04, 2015 9:13 am  (#12)
I did another try, I think it is a little closer to an icy look but not totally. I must practise much more. :)
PostPosted: Fri Dec 04, 2015 12:56 pm  (#13)
Image Thanks Lyle. I worked it out. My Pines have turned into Jacarandas which is appropriate for Queensland in Summer. I like to do snowy pictures to take my mind off the heat.
PostPosted: Sat Dec 05, 2015 3:03 pm  (#14)
Lyle, I've tried hard to get a closer result to yours, but it's impossible even using metallic something. Any other tip, please? :tyspin
PostPosted: Sat Dec 05, 2015 8:03 pm  (#15)
Again, when you have two layers, then, either convert the top layer to b/w or run the engrave preset and then run Delaunay on both layers setting the top layer to difference, you will get a more crystallized result. If you run it on your target, the result will look more like what you have (and indeed I originally had to do all kinds of manipulation on the elf original and still wasn't happy with that result). :)
PostPosted: Sun Dec 06, 2015 5:43 am  (#16)
Thank you so much Lyle for your patience, I did this other new try. :)
PostPosted: Sun Dec 06, 2015 12:50 pm  (#17)
Now you got it. Do some level adjustments and use the metallic something gradient mapping and you would get a result like mine (prior to the sparkle step and other blends that I sometime add such as my ruby texture (did I not tell you all that too? lol). I do this very subtlety; almost not necessary, but for the large dark voids, it helps (of course I desat/adjust the color as I see fit with this texture as well as lower the opacity to taste). :)
PostPosted: Sun Dec 06, 2015 2:53 pm  (#18)
Thank you Lyle. Nice ruby texture, I'll use it. :bigthup :tyspin
PostPosted: Sun Dec 06, 2015 4:34 pm  (#19)
Darn, just discovered I don't have the engrave filter. I cannot add new filters until I get a new mcgimp with the latest G'mic. sigh.
PostPosted: Sun Dec 06, 2015 5:40 pm  (#20)
You can try other blends such as paint then dup and apply cartoon (both G'MIC presets that's been in existence for a while) 2-ton. The blend possibilities are limitless. Just play I say. Don't take anything I share as gospel. More than one way to skin a cat. :)
