It is currently Fri Nov 27, 2026 6:05 am
 Post subject: Simple Single Leaf Holiday Wreath
PostPosted: Tue Dec 22, 2015 7:21 pm  (#1)
Using a simple leaf that I photographed today, combined with the magic of GIMP, I made a holiday wreath. The tones in the slowly decaying leaf created for a design that only nature can provide in my opinion.
Here is the final result:
Also, a Christmas specific one:
Thank you for checking this out.
General Explanation How This Was Made (for those curious)
I photographed this leaf:
The original sized image is much larger. I included the original sized image as an XCF file if anyone else wants to use it in a project. By all means feel free if you feel inspired to do so.
At first I adjusted the size of the original photo and then placed the leaf inside a 600x600 px image with a transparent background. Then using Map Object in Plane mode, I rotated copies of the original successively by 10 degrees and ended up with this:
I used Map Object in Plane mode for the rotations because I find it gives good consistent results compared to using the Rotate Tool. I didn't try the Rotate Tool this time, but perhaps it would have been equally effective. I've just had issues with the Rotate Tool in the past. Those issues are due to how Gimp calculates the rotated layer.
I combined those layers and then again using Map Object, rotated copies of the original group of six leaves by 60 degrees, ending up with:
I had to apply a Layer Mask to the top layer, using the first layer alpha to selection and reducing the selection by 1 pixel to arrive at:
Then applying other steps, I arrived at the images shown above.
I've also included an XCF file showing the layers used to arrive at the wreath. Again, feel free to use it if you feel so inspired to do so. Thank you.
leaf_only_wreath.xcf [1.63 MiB]
Downloaded 606 times
leaf_transparency.xcf [642.4 KiB]
Downloaded 489 times
 Post subject: Re: Simple Single Lealf Holiday Wreath
PostPosted: Tue Dec 22, 2015 7:25 pm  (#2)
Thank you for the beautiful wreath and the tutorial. It's been a long time since I've seen you in here. Nice to see you. :coolthup
Happy Holidays, ccbarr!
PostPosted: Tue Dec 22, 2015 8:10 pm  (#3)
Nicely done CC. :)
PostPosted: Tue Dec 22, 2015 8:57 pm  (#4)
Very good ccbarr :)
PostPosted: Tue Dec 22, 2015 9:15 pm  (#5)
Nice design. :bigthup
PostPosted: Tue Dec 22, 2015 11:31 pm  (#6)
Nice work.
PostPosted: Tue Dec 22, 2015 11:40 pm  (#7)
Thank you very much ccbarr. I now have another project to learn! Happily so. Happy Holidays!
PostPosted: Wed Dec 23, 2015 1:59 am  (#8)
nicely done ccbarr, thanks for sharing. :)
PostPosted: Wed Dec 23, 2015 9:57 am  (#9)
Thanks for the tutorial, good to know for all sorts of projects!
*well, I could not figure out how to rotate it in the map object filter set up. And it didn't help that my gimp was being 'gimpy', sometimes the pointer is off just enough that you have to adjust to click on the right spot.
PostPosted: Thu Dec 24, 2015 9:26 am  (#10)
Hey it's great to hear from you again! :) Nice tutorial. Thank you.
Hope to see more of your ingenious animation tutorials soon. Happy Holidays friend.
PostPosted: Thu Dec 24, 2015 11:49 am  (#11)
Very nicely done ccbarr. Your tutorials are all so nicely explained.
Merry Christmas to you and your family and thank you.
Also, very nice to see you on the forum again.
PostPosted: Tue Dec 29, 2015 9:07 pm  (#12)
I just had to do this tutorial. I must admit it drove me "nuts" at first. I had some trouble learning how to use map object. Then that last step with the layer mask stumped me for awhile. I still can't figure out how that 1 pixel made such a difference!
I am still glad that I did it as I learned a lot more of gimp's abilities! It is hard to believe it was all from a leaf!
PostPosted: Tue Dec 29, 2015 10:38 pm  (#13)
Nice one, Pat625 :bigthup
PostPosted: Wed Dec 30, 2015 1:31 am  (#14)
Thank you very much,Odinbc. I really enjoyed doing it.
PostPosted: Wed Dec 30, 2015 3:49 am  (#15)
From this PD image
I made this - forgot to turn off the 'light' in map though :oops:
I followed most of your steps otherwise. I may try it again
PostPosted: Wed Dec 30, 2015 4:10 am  (#16)
Thanks ccbarr again, I add your tut in PDF file for if needed. :)
Simple Single Lealf Holiday Wreath By ccbarr.pdf [341.25 KiB]
Downloaded 316 times
PostPosted: Mon May 23, 2016 1:27 am  (#17)
I need help with using the map to object, plane script. I did this tutorial before but could not remember how to work the script. When I try to rotate my image, it jumps to the left upper corner no matter what x,y, or z coordinates I use.
How do you set the values to rotate your image?
PostPosted: Mon May 23, 2016 4:06 am  (#18)
You can use Map to Object,
but I did it using the Rotate Tool.
This is the position that I put the little paisley in before rotating it.
I Autocropped the paisley layer and moved it into the position above.
Making sure to set the layer back to it's original size before rotating.
Here are the setting I would use if using Map to Object.
Here is the setting using the Rotate Tool.
PostPosted: Mon May 23, 2016 2:45 pm  (#19)
Thank you very much Wallace for your help. I had forgotten to put the image back to the regular size before running the Map script. Must have had another "Senior Moment". (I'm sticking to that story anyway!)
PostPosted: Mon May 23, 2016 2:53 pm  (#20)
I understand. :hehe
However,
you may find that this script will do the job much faster.
viewtopic.php?f=9&t=14116&start=20#p193157
