It is currently Tue Nov 24, 2026 9:24 am
Post new topic Reply to topic  [ 302 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
 Post subject: Clear Glass Brumbies (wild horses) Landscape
PostPosted: Tue Jan 05, 2016 10:47 pm  (#1)
I was again asked to create a tutorial on an image previously posted in my Glass Ornaments & Effects thread.
So here is a PDF tutorial to create these clear glass brumbies; I have also included a starter.xcf file and the gemclear.png e-map which is used to create glass images using the Bevel Reflect Logo plugin.
Proof reading my own work is an exercise that does not always yield good results, so please let me know of any errors or problems you experience.
Have fuin
File comment: PDF file, starter.xcf and e-map
OMG Clear Glass Brumbies Tut(2).zip [4.41 MiB]
Downloaded 1428 times
 Post subject: Re: Clear Glass Brumbies (wild horses) Landscape
PostPosted: Tue Jan 05, 2016 11:40 pm  (#2)
Thank you very much, OMG. I can't keep up. I'm working on the glass vase and you are miles ahead!!
I'll start the brumbies as soon as I finish the vase! Love doing this.
PostPosted: Wed Jan 06, 2016 11:02 am  (#3)
Thank you so much OMG, your tut is absolutely great and helpful. Here my first result. No good but I've learnt a lot. :tyspin :bigthup
PostPosted: Wed Jan 06, 2016 3:24 pm  (#4)
I repeated the steps with a different brumby. This time it has a whiter glassy look. I'll practise more times. :) :tyspin OMG
PostPosted: Wed Jan 06, 2016 5:07 pm  (#5)
Issabella - thank you for trying out the tut; keep trying as it took me quite a while to figure out the best 'blends' each time for different images.
You do seem to like those 'dramatic' backgounds ;)
PostPosted: Wed Jan 06, 2016 5:33 pm  (#6)
Image This the Original.
Image This one has a Drop Shadow.Image And on this one I moved the Drop Shadow layer to the top and changed the blend mode. I also changed the opacity on Ghost and Smoked Drop Shadow layers to 50%. Thanks OMG for a clear and Informative tutorial.
PostPosted: Wed Jan 06, 2016 7:06 pm  (#7)
Kimba - thank you for doing the tut and posting all your 'modified' results!
I am also glad that the word 'brumby' has gone global :hehe
PostPosted: Wed Jan 06, 2016 8:09 pm  (#8)
Issabella, your Brumby is really beautiful! Your dramatic background really does a wonderful job of showcasing the Brumby.
Kimba, I love your Brumbies. The original ones you did. That's because I'm on such a quest to get that clear glass result! I'm still working on mine. Sometimes that BRL takes hours for just one image. It's over 3 hrs. For this one now. Wish me luck!
PostPosted: Thu Jan 07, 2016 10:38 am  (#9)
Thank you OMG, I'm glad you like my tries. But I need more practice. ;)
Kimba, your brumbies are great in your try. :bigthup
Pat, thank you for your nice words. Waiting for your tries, too. I'm sure they will be fantastic. :bigthup :)
PostPosted: Thu Jan 07, 2016 7:41 pm  (#10)
Wow! I finally have my first try of OMG's Brumbies done!! I started out OK, but then had to stop. Next day, nothing would work correctly with Gimp. Worked at it a long time when it finally dawned on me that I had a lot of updates for windows load in the day before. I was told when there are a lot of updates, sometimes problems arise. Our internet server had to give me our router info to load into the computer one time after updates so I could get on the internet. Oh, well. Reloaded Gimp and now all seems fine.
PostPosted: Thu Jan 07, 2016 8:44 pm  (#11)
They look great, Pat. I know what you mean about upgrades. I upgraded my Linux Mint and I rebooted and nothing would work right. Took an message to the website to work out my issue. They had moved things around and I needed to change a setting or two.
PostPosted: Thu Jan 07, 2016 9:32 pm  (#12)
Thank you Kimba. It is frustrating when you can't get something to work that always has. Now I'll know not to play with it so long before I re download the program or call Windows! Another learning experience.
PostPosted: Thu Jan 07, 2016 9:50 pm  (#13)
Pat625 - wow Pat so very well done, I am so pleased for you :) :jumpclap
One thing though Pat, you might just want to go and check where your 'highlights' are, as neither brumby has them showing - they may just be invisible.
As for Windows upgrades the last upgrade on my notebook totally disabled my home network :hoh
Kimba - I also run Linux Mint as my music machine and have never had any Update problems with it.
PostPosted: Thu Jan 07, 2016 10:58 pm  (#14)
OMG: You are correct. I cannot see the highlights. Tried to fix. Hope this is better.
PostPosted: Fri Jan 08, 2016 1:08 am  (#15)
I had made the mistake of loading Compiz which was far too heavy for my laptop, OMG, but I couldn't get rid of it without practically reinstalling Linux. When I upgraded they reckoned they had made Compiz easier to change for another window manager. Not quite as easy as I hoped but after being told what settings to change I rebooted and it was gone. :yes
PostPosted: Fri Jan 08, 2016 1:54 am  (#16)
Pat, Congrats! you got a beautiful result with your brumbies. :clap
PostPosted: Sun Jan 10, 2016 9:39 pm  (#17)
I love this tutorial so much that I just had to do another! Takes me awhile though. This time, since I had two big Siberian Huskies visiting with me this Christmas, I thought I would use images of Huskies.
PostPosted: Mon Jan 11, 2016 12:55 am  (#18)
Pat625 - I'm so impressed by your perseverance, your outcome and I also love large dogs. :) :clap
In fact one of my favourite sayings, probably because we had Borzois, is that "...it is not a real dog if you have to bend down to pat it!"
PostPosted: Mon Jan 11, 2016 5:00 am  (#19)
Pat, your last outcome is great, too. Well done! :clap
PostPosted: Mon Jan 11, 2016 12:15 pm  (#20)
OMG: I'm honored that you like my Huskies! Thank you. I have always been partial to larger dogs. They are such good companions, helpers, and protectors.
Issabella: Thank you for your comment. Your creations are beautiful and I look forward to them.
