It is currently Sun Nov 29, 2026 8:48 pm
 Post subject: An Example of Guides Plugin
PostPosted: Fri Feb 05, 2016 1:35 am  (#1)
I used 'Add Multiple Guides' for making this picture. It helped me a lot while drawing lines of the page. As I don't understand German language so I didn't change anything except the distance in pixels.
Any criticism is welcome.
 Post subject: Re: An Example of Guides Plugin
PostPosted: Fri Feb 05, 2016 1:58 am  (#2)
I added that plug in and at first I couldn't locate it, but I did. It's a nice plug in, I just wish it was in English.
PostPosted: Fri Feb 05, 2016 2:18 am  (#3)
prozentual = percentage
hilfsline = alternate line
At least according to google translate which is not known for it's .... ummmm ... reliability?
and
Rashid!
(Solve if you can ... ;) )
PostPosted: Fri Feb 05, 2016 2:23 am  (#4)
Thanks for the translation, Jazzon. :)
Welcome to Gimpchat, Rashid
PostPosted: Fri Feb 05, 2016 2:40 am  (#5)
A version in english for you. Uninstall the old one before installing this one.
File comment: English Variant
add_multiple_guides_plug-en.py.zip [2 KiB]
Downloaded 746 times
PostPosted: Sat Feb 06, 2016 12:02 am  (#6)
Thanks for welcome.
Thanks for English version of script.
I want to share with all of you the final result of incomplete image which I have posted yesterday.Gardening is my hobby as I love the plants. So this image utilizes two photographs of a small herb. Magnifying glass comes from PS tutorial and Paper effect comes from an Indesign tutorial. So this image involves many different techniques.There may be some flaws due to the absence of some tools/effects in gimp.
PostPosted: Sat Feb 06, 2016 3:51 am  (#7)
I made a few improvements/changes to the image.
There are 3 changes that I made.
Can you spot them?
PostPosted: Sat Feb 06, 2016 6:20 am  (#8)
The 3d depth on the holes
Fixed see through shadow on first "ring" of handle.
You either A adjusted overall darkness of internal image of the earth, or B adjust the shadow of the magnifier in that region. Eyes are to old be sure which.
PostPosted: Sat Feb 06, 2016 9:01 am  (#9)
simply applying my modLCS (default)
PostPosted: Sat Feb 06, 2016 9:52 am  (#10)
This script is great! I can use this.
PostPosted: Sat Feb 06, 2016 10:32 am  (#11)
Glad I could help PegLeg44! GimpOn!
PostPosted: Sat Feb 06, 2016 12:13 pm  (#12)
2 out of 3.
The shadow of the paper's holes and the small missing shadow near the upper part of the handle.
You get a cookie...Image
PostPosted: Sat Feb 06, 2016 6:11 pm  (#13)
Contrasr adjust the inner part off the image. It is lighter.
PostPosted: Sat Feb 06, 2016 8:05 pm  (#14)
Nope... :roll:
PostPosted: Sat Feb 06, 2016 11:13 pm  (#15)
Thank you Rashid, for the nice plug in, Jazzon for putting it in English. I like it very much!
PostPosted: Sun Feb 07, 2016 1:10 am  (#16)
Thanks for comments.
I was able to locate drop shadow of the punch holes. This really improved the natural appearance of the page. Secondly I felt as if the jagged rim of the magnifying glass were more smooth.
I drew the magnifying glass while following a Photoshop tutorial. I was so pleased to complete it in Gimp that I gave up the further refinement of the image. Perhaps original tutorial is without this shortcoming.
Thanks once again.
PostPosted: Sun Feb 07, 2016 2:55 am  (#17)
Ok Wallace, I cant take credit for spotting it, although I should have seen it. But Rashid is right, the edges are "cleaner" somehow. How did You do that ?
PostPosted: Sun Feb 07, 2016 2:00 pm  (#18)
That was the final 3rd modification I added to the image.
It's was done using the paths tool.
Stroking a line, one on the outside rim, as well as the inside rim.
Applying a slight Gaussian Blur to both lines and lowering the opacity to blend better.
A cookie for you too Rashid
PostPosted: Tue Mar 01, 2016 2:53 am  (#19)
Thank you Rashid!. This makes setting the guides for a composition or image so easy. I love it.
