It is currently Sat Nov 28, 2026 12:11 pm
 Post subject: Text Card Tutorial
PostPosted: Sat Apr 30, 2016 3:40 am  (#1)
Hi guys,
I posted a new easy tutorial here---> http://www.asganafer.it/text-card/
The only things you need are custom font and Script Fu for some effects! :)
Try to do it and post here final work! :D :tyspin
 Post subject: Re: Text Card Tutorial
PostPosted: Sat Apr 30, 2016 7:36 am  (#2)
Thank you so much Asganafer. I'll try it. Thanks for sharing. :) :tyspin
PostPosted: Sat Apr 30, 2016 7:45 am  (#3)
I post your tutorial in PDF file in English. :)
131.253.14.125 - proxy-English.zip [367.63 KiB]
Downloaded 491 times
PostPosted: Sat Apr 30, 2016 9:15 am  (#4)
Issabella, the zip tutiorial you posted is for a supernova and it's not english.
I wouldn't mind both of them in english.
PostPosted: Sat Apr 30, 2016 9:21 am  (#5)
Thanks Serious Tom, I thought the same as you, but it is right, take a look at page 5, it's part of the tutorial too. :) Mine is in English. I'll check it.
PostPosted: Sat Apr 30, 2016 9:24 am  (#6)
Try it with this one.
Downloaded 524 times
PostPosted: Sat Apr 30, 2016 10:45 am  (#7)
Thanks Asganafer, it's nice and professional this design yours. Something I've invented when I was lost, but I think that I got your idea. :) :tyspin :coolthup
