It is currently Fri Nov 27, 2026 5:22 am
 Post subject: Super Basic Wood Background
PostPosted: Sun Jun 05, 2016 4:03 pm  (#1)
Someone was asking about making a faux wood background and this is my little quicky that I use. I'm sure that there are many more that are much better, but this is a super basic on that I think might come in handy for someone.
And this is the resulting image. It makes me think of a wooden deck.
My Sigs = My Photos
 Post subject: Re: Super Basic Wood Background
PostPosted: Sun Jun 05, 2016 4:12 pm  (#2)
I like that! It can be any size and it's not tiled like the wood patterns in Gimp. There is something to be said for making things by hand from scratch, I should do more of it.
Very nice tutorial, although I can't say much for my inability to make a decent knot, lol.
PostPosted: Sun Jun 05, 2016 7:37 pm  (#3)
Thank you, PhotoMaster. I think that this can come in handy. Gives a good result.
PostPosted: Sun Jun 05, 2016 8:46 pm  (#4)
I agree.
Knowing how to create your own wood grain can be really handy.
Cool tut! :coolthup
PostPosted: Sun Jun 05, 2016 8:51 pm  (#5)
Great tutorial PhotoMaster. Will play with this one a lot more. Like 2-ton I agree it is so much better to make what you need and, also like 2-ton, couldn't get my knots right :oops:
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Mon Jun 06, 2016 1:01 am  (#6)
PhotoMaster, Thank you so much for this useful tutorial. I'll do it for sure. :) :tyspin :coolthup
PostPosted: Mon Jun 06, 2016 8:27 am  (#7)
How can this, or any pattern, be made seamless? I cannot find instructions even though I know they are here somewhere...I am terrible at the search page.
PostPosted: Mon Jun 06, 2016 9:57 am  (#8)
Thanks PhotoMaster. It has been funny and easy! :bigthup
2-ton, I have it in Filters-Map-Make seamless. but this pattern can't be done seamless in Gimp by this way. Have you looked for it in GMIC?
PostPosted: Mon Jun 06, 2016 10:09 am  (#9)
2-ton, I did it seamless in GMIC - Arrays & Tiles - Make seamless patch-based. Then I adjusted it a little and I got this.
PostPosted: Mon Jun 06, 2016 10:12 am  (#10)
Thanks guys! I need to make some kind of filter list with tags so I can find things! I never seem to look in the right places.
PostPosted: Mon Jun 06, 2016 11:05 am  (#11)
Here I duplicated the Bump layer prior to blurring it and placing the un-blurred copy above the wood layer. I set it to Grain Extract and merged it with the wood layer. This gave it more wood texture. This could be step 7a.
My Sigs = My Photos
PostPosted: Mon Jun 06, 2016 11:14 am  (#12)
Very. Ice photomaster
PostPosted: Mon Jun 06, 2016 12:35 pm  (#13)
Very good guys :)
Terrific Tutorial Photomaster. I'll have to try it in the nest day or two.
PostPosted: Mon Jun 06, 2016 2:40 pm  (#14)
PhotoMaster, question, how do I achieve the "edges of bell curve". Have to be honest - left that part out perhaps the reason my texture doesn't look as defined?
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Mon Jun 06, 2016 3:14 pm  (#15)
Dalia, After a while, I thought that it meant that you adjust black and white triangles just to the edges of the black bell shape that you see when you open levels. :)
PostPosted: Mon Jun 06, 2016 6:01 pm  (#16)
Thank you Issabella will try it again.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Mon Jun 06, 2016 6:40 pm  (#17)
This is correct. Sorry if it wasn't clear.
My Sigs = My Photos
