It is currently Tue Nov 10, 2026 7:20 am
 Post subject: Circle Paper Number
PostPosted: Wed Aug 03, 2016 1:19 pm  (#1)
Hi to all,
today i want to share with you my new tutorial!
Is very easy and "conceptual" :paint
The tutorial is here --> http://www.asganafer.it/circle-paper-number/
I hope you like it! Try to do it and share with me your artwork! :)
 Post subject: Re: Circle Paper Number
PostPosted: Sat Aug 06, 2016 12:00 am  (#2)
Is there any way to translate the page into English? Or can you provide us with a pdf in English if not
PostPosted: Sat Aug 06, 2016 12:37 am  (#3)
Hope you don't mind but put it here with translation to help others. :)
Let's start creating a new image (1920 x 1080) to which we apply now a gradient ( Gradient tool ) from white to color # f4f4f4 .
We select the Elliptical Marquee tool and holding the SHIFT draw a circle button . Once the selection is active we take the gradient tool and draw from light grigoi color ( # fefdf9 ) to the darker color ( # e9ebea )
To better highlight the outline of our button we must draw him a thin edge ( in this case given the 4px image size will be fine ) . To do this we use the Script - Fu > Layer Effect- > Stroke setting as in the image :
Once we are drawn the edge we need to create a small shadow to give it a more three-dimensional effect and enhance the more button. For the shadow always go in the menu Script -Fu below LayerEffect- > Drop Shadow 's voice
Now that we have created the shadow give a bending " effect " and to do that we will use the smudge tool . Select it , and we set the large brush size as our button , we set the frequency of the instrument at 100 and duplicate the shadow layer . Once everything is ready we drag down slightly to the left so that the blurred shadow both in the same direction in the light color of the button .
The button is already done, you only need to write the number we want inside . The font used is to IronMan (you can find the link at top of this article ) and the color used is # 2c2c2c ( dark gray ) .
To bring out the number we create internal shadows going on Script Fu > Layer Effect- > Inner Shadow , and as fate above we set the parameters as in the image .
To mitigate the inner shadow sfumiamo clicking Filters- > Sfocature- > Gaussian selecting 15 as the radius of blur .
This is the end result : elegant and very beautiful Simple ! How about you?
PostPosted: Thu Oct 27, 2016 1:20 am  (#4)
Hi Guys,
As I needed only six digits so I created them.
I hope that they may become useful someday for some gimp user.
Thanks.
PostPosted: Wed Sep 10, 2025 3:56 pm  (#5)
Hi resurrecting this 10 years later... Is there maybe a plugin that can help with this? I guess this is of common use to pointing out on tutorials with screenshots. I've seen satty a tool to annotate that allows to select the color and the number. I would love this in gimp3. Thanks in advance.
