It is currently Fri Nov 27, 2026 1:09 am
 Post subject: Neon Fountain Animation Tutorial
PostPosted: Thu Sep 22, 2016 7:07 pm  (#1)
In this tutorial I will show you how to create an animation similar to this:
The tutorial will require the following scripts to expedite the process....
Animated Fire
Polar Coordinates All Layers
Gaussian Blur All Layers
Plastic Wrap All Layers
Edge Detect All Layers
After downloading the scripts, place them in your GIMP Scripts folder (ie...C:\Users\Name\.gimp-2.8\scripts). Refresh your scripts and you're ready to go. I will point to the appropriate menu location at the right time.
The settings I'm providing are only examples. As always, I encourage you to experiment.
Let's begin!
Step 1
On a new image, go to Filters > Animation > Animated Fire... and choose the following settings (I'm going with the script’s default settings).
Click OK and you should have an animation that resembles this (mine's not animated, just showing the top layer)
Step 2
Let's blur the fire animation to smooth things out a little bit. Go to Filters > Blur > Gaussian Blur All Layers... and apply these settings (again I’m using the defaults):
Click OK and your image will now resemble this:
Step 3
Next, we're going to give additional motion to the flames by running the Animated Polar Scripts filter, which is found here: Filters > Distorts > Polar Coordinates All Layers... Use the following settings:
Click OK and you should have an image that resembles this:
Step 4
I discovered that we need to add some shiny spots to the animation to give the final result the effect of "flying bits". To add the shine, we'll use the Plastic Wrap All Layers script. It's found under Filters > Light and Shadow > Plastic Wrap All Layers... I'm using the following settings:
This script works differently with each gradient type. I recommend that you use higher numbers at first (adds less shine) and run the script a second or third time to get the desired effect. Too much shine may result in a "busy" result. Again, experiment.
Click OK and here's the result:
Notice there's just a little shine.
Step 5
Now, to finish the animation, we'll use the Edge Detect All Layers script (Filters > Edge-Detect > Edge Detect All Layers...) using the following settings:
Click OK
Your animation is now finished and should look something like this:
I hope you enjoyed this tutorial. Let me know if you need clarification.
Happy GIMPing!!
Art
Neon Fountain Animation Tutorial (PDF)
 Post subject: Re: Neon Fountain Animation Tutorial
PostPosted: Thu Sep 22, 2016 7:56 pm  (#2)
Nice one fencepost :coolthup
PostPosted: Thu Sep 22, 2016 8:11 pm  (#3)
thanks!
PostPosted: Thu Sep 22, 2016 9:09 pm  (#4)
Fencepost I'd like to see all the scripts put together in a Neon Fountain script
PostPosted: Fri Sep 23, 2016 12:18 am  (#5)
On this one I left out the final part
PostPosted: Fri Sep 23, 2016 1:13 am  (#6)
Thank you so much Fencepost, I post your tut in .pdf :)
Neon Fountain Animation Tutorial by FENCEPOST.pdf [414.68 KiB]
Downloaded 571 times
PostPosted: Fri Sep 23, 2016 3:32 am  (#7)
Image Thanks Fencepost. I added the "Feathers" Gimpressionist preset to give more texture and I also left out the last step.
PostPosted: Fri Sep 23, 2016 6:57 am  (#8)
Thanks for this cool tutorial and the scripts FP! :)
I decided to colorize all layers the same copper color. Although i did name it "Fountain Of Gold".
PostPosted: Fri Sep 23, 2016 7:36 am  (#9)
By the way fencepost, is it possible to script a colorize all layers filter using gimp-colorize?
PostPosted: Fri Sep 23, 2016 10:53 am  (#10)
I'm responding on my phone, so forgive me if I mess up. Lol
Thanks, everyone, for trying out the tutorial. The results look great. Experiment with different script settings and see what you can come up with.
Thank you, Isabella, for converting it to a PDF. That's a great idea.
Graechan, I'll see if I can come up with a single script. My skills are quite rusty!
Rod, I'll check into that. I'm thinking I may have started writing one for colorize. Will let you know
PostPosted: Fri Sep 23, 2016 11:20 am  (#11)
I did my FireMountain, too. Thanks you fencepost. It's been funny and easy. :) :bigthup
PostPosted: Fri Sep 23, 2016 3:56 pm  (#12)
Thanks for the tutorial .... Love animation.
PostPosted: Fri Sep 23, 2016 7:52 pm  (#13)
Awesome! Nice work, Issabella and SeriousTom!
PostPosted: Sat Sep 24, 2016 8:32 am  (#14)
Fencepost I did a script for you that I'll send in a PM in the morning :bigthup
PostPosted: Sat Sep 24, 2016 8:51 am  (#15)
I'm writing one right now. BAHAHAHAHA
Yes, send it to me and we'll compare notes! :tyspin :clap
PostPosted: Sat Sep 24, 2016 9:16 am  (#16)
FP, why don't you submit your scripts to Gimp Scripts and Plug-ins?
http://gimpscripts.com/
easy access for all gimp chatters
PostPosted: Sat Sep 24, 2016 9:38 am  (#17)
I have a number of them posted there and I'll certainly add these. I also like to host them on my deviantart account for those people who watch me there.
PostPosted: Sat Sep 24, 2016 8:49 pm  (#18)
My script has gone to you via a PM, it's up to you to add whatever menu items you think are important or have an influence on the script
gradient full saturation spectrum
PostPosted: Sat Sep 24, 2016 9:24 pm  (#19)
I really like that, Graechan.
PostPosted: Sat Sep 24, 2016 11:00 pm  (#20)
Finally! I tried to upload this file yesterday but I kept getting a weird error message and would not upload. Today the same thing. I changed the title drastically and it finally uploaded.
FencePost: Love this script. If you like to write tutorials, I would love to learn more about animation. I believe there are others that would also. Would need to start out very basic, and progressively get more complicated. Maybe this has already been done, and I haven't found it. If
you know of these tutorials, would you let us know? I have always found animation intimidating.
