It is currently Wed Nov 25, 2026 10:32 pm
 Post subject: Advanced photomanipulation tutorial - Book of incredibles
PostPosted: Fri Oct 21, 2016 2:18 pm  (#1)
Hi guys,
after a lot of time without any tutorial i'm here with one of the best tutorial i have never done!
I hope you like it, and i hope you'll try to do ( post your final artwork in the comment ;) )
You can find the first part of tutorial here --> http://www.asganafer.it/book-of-miracles-part-1/
Comment here if you like it!
Good paint! :D :paint
 Post subject: Re: Advanced photomanipulation tutorial - Book of incredibles
PostPosted: Fri Oct 21, 2016 5:19 pm  (#2)
Asganafer,
Investigated your tutorial and found it very informative.
The results are very very striking.
Noticed that it was posted on the website in the Italian language.
So I am in process of translating it so that I can utilize in the future.
Thank You,
Mainah_Ayah
(Following translated via Google translate, please excuse any incorrect meanings.)
In seguito tradotta tramite Google Translate, scusate eventuali significati non corretti.
Idagato il tuo tutorial e l'ho trovato molto istruttivo.
I risultati sono molto molto sorprendente.
Notato che è stato pubblicato il tuo sito web in lingua italiana.
Quindi io sono in fase di tradurlo in modo che possa utilizzare in futuro.
Grazie,
Mainah_Ayah
PostPosted: Sat Oct 22, 2016 12:07 am  (#3)
Great detail. Adding the birds flying and the clouds really sets it off. :)
PostPosted: Sat Oct 22, 2016 2:59 am  (#4)
In the future i will translate all my website in english! :)
PostPosted: Sat Oct 22, 2016 6:33 am  (#5)
What is it that you can put on your page that a user can ask for the preferred translation and it is done for them? (Usually icons of maps) You will not have to do it then.
http://translate.google.com/manager/website/?hl=en
PostPosted: Sat Oct 22, 2016 8:32 am  (#6)
WOW!!!!!!!!!!! Very Nice!!!!!
PostPosted: Sat Oct 22, 2016 11:30 am  (#7)
Sallyanne :tyspin
Thank you so much for that link.
Now i can expose my forum to the world in multiple languages.
I wonder why Gimpchat.com don't use it.
PostPosted: Sat Oct 22, 2016 11:38 am  (#8)
Thank you so much Asganafer, amazing tutorial. :tyspin :coolthup
Sallyanne, thanks for the link, very useful :) :tyspin
PostPosted: Sat Oct 22, 2016 3:45 pm  (#9)
Thank you for a brilliant tut Asganafer, really fires the imagination and take stock of the learning curve.
Here's my first attempt.
PostPosted: Sat Oct 22, 2016 4:30 pm  (#10)
good job RJKD! :jumpclap
PostPosted: Sun Oct 23, 2016 1:43 am  (#11)
You did it!!! RJKD :jumpclap
PostPosted: Sun Oct 23, 2016 3:40 am  (#12)
Thank you guys for answer!
@RJKD good work! I like the moto! :D Next week you can complete your work with the second part of tutorial! ;) :paint
PostPosted: Sun Oct 23, 2016 5:04 am  (#13)
I have a kind of confession - I didn't use a single layer mask, that's my homework for next week. I haven't got my head round masks yet. I used paths, selections and cut and paste. Thank you for the direction :tyspin
PostPosted: Sun Oct 23, 2016 8:32 pm  (#14)
A translation of Asganafer's Book of incredibles tutorial from Italian
to English utilizing Google Translator has been completed.
There is a minimum post rule that precludes me from attaching
a file or document to message(s) until the post rule minimum has been met.
A multi-page PDF file of the tutorial translation that includes all required
images is available for any Gimper that requests it from me via PM.
Mainah_Ayuh
PostPosted: Sun Oct 23, 2016 8:34 pm  (#15)
You will be able to post images after a minimum number of posts. I think the number is 5 posts.
PostPosted: Thu Oct 27, 2016 2:37 pm  (#16)
Ok, I've got my head round the basics of layer masks, however, I can't figure out why I'm making a mask of selection in step 1 of the tutorial? I only have transparency where the book was. Can anyone explain please?
PostPosted: Fri Oct 28, 2016 9:40 am  (#17)
Nice tutorial. Thank you for sharing it.
PostPosted: Sat Oct 29, 2016 2:10 am  (#18)
@RJKD you make selection if you have a white background or a not transparent background :) In this case is not necessary :)
PS: here you can fine d the second part of tutorial --> http://www.asganafer.it/book-of-miracles-part-2/
PostPosted: Sat Oct 29, 2016 4:59 am  (#19)
Fantastically wonderful result for sure Asganafer. Thanks for sharing. :)
PostPosted: Sat Oct 29, 2016 5:52 am  (#20)
Thank you Asganafer, your a star :tyspin
